Is there any reason why you shouldn't have a low level extractor fan for a toilet? I imagine it's good to have it high in steamy rooms, but that doesn't apply. High level is crowded in ours due to a high level cistern. Would be easy enough to have the extractor fan at around 300 - 500mm off the floor.
11 hours ago, TonyT said:
Generally it was always the furthest point from the bathroom door, up high..
I guess it makes sense to draw air across the room from the door. If not in the ceiling, I don't see a reason for it to be at any particular height other than too low could be a vermin risk.
Ar$e level! 👍
It’s there for removal of water vapour and heat rises hence why they are mounted high up. Without it you may get mould at a higher level.
48 minutes ago, Dave Jones said:
use a wall hung frame with built in bog extraction.
That is supplemental extraction, not fundamental extraction. Would go WITH the main extractor, not replace it.
4 hours ago, Conor said:
Air is drawn in UNDER the door, so all you'll be doing is extracting fresh air from the hallway.
Could always put a transfer grille above the door and leave very little gap at the bottom. Then airflow would be from top to bottom, as best as.
In a bathroom sure, but also in what's just a toilet?
Depends if it has a window really, because of water in the cistern and running water / damp towel from hand washing in what is a very small compartment.
In this situation, any extraction should suffice afaic, but doing as I stated above would get the best results from a low down extraction point as the incoming air would be coming in up high creating at least some  turbulence within that compartment.
  • 4 months later...
But looks like the window could count as an alternative so extractor fans not actually required for toilets (without bath or shower). I'm a but surprised so would need double checking with BCO. If extractor not required you could add one in a non compliant position.
