Hi
Anyone got any tips for the best way to cut 110mm  holes in 100mm PIR for the waste pipes, I can’t find any hole saws deep enough to go through the 100mm Celotex
I found a wood jab saw from screwfix £4.99 , 300mm long to cut my 250mm slab insulation. Same as a pb saw but longer if needed.
I’ve got a 110mm hole saw somewhere that got “modified” with a slot cut into the top and then the edge bent down to cut through EPS as it basically acts like a food processor blade and chops the core out as it goes - it’s not pretty but works ..! Now if I can remember where it is …..
