I currently have the following ovenSiemens HB676GBS6B/13.  It is five years old.
Last week, it overheated, an alarm message eventually showing saying the appliance was too hot.  The main 2200W element was glowing red hot.  The temperature control showed the oven heating, but for some reason failed to maintain the set temperature, i.e. the element stayed on and kept heating the oven.
I've just replaced the PTC sensor, and temperature limiter, but on testing, the problem remains - the oven is not regulating temperature (main element).
Looking at the spare parts exploded view:
https://www.siemens-home.bsh-group.com/uk/supportdetail/product/HB676GBS6B/13#/Tabs=section-spareparts/Togglebox=tb0420/
The only other things that I can think of changing are the element itself, and the control module.  Given the element is working, and in of itself, appears dumb / nothing more than an element, the control module (£166) seems the only realistic answer.
I will be testing whether the oven functions normally just using top and bottom element heating later today (once it has cooled down from the earlier test).
Any thoughts or other suggestions.
It will almost certainly be the control module.  Probably a stuck relay.  I tried to fix a similar problem with a neighbours Siemens Oven but found the control module not available for his.
Just tested the top/bottom heating function - as well as the top element, the main element came on, red hot, pushing well beyond set temperature.
Control module are available, sadly they cost £166
If the relay is stuck on, how are you able to isolate the oven? I picture it being permanently on. If not then something's interrupting the power to the element.
The one I looked at, different but similar oven, as soon as you selected any heating function with the big rotary switch, it supplied power to this control board.  the relays then determined where that power went, to which element or fan.  The control board was "told" which heating mode you had selected by 4 low voltage contacts on the switch sending a binary code to the control board.  So turning the big rotary switch to off, killed all power regardless of stuck relays.
In the case of my neighbours one, it was the oven fan permanently stuck on, not a heating element.
When you switch the oven on, you select the heat type (function) and set temp via digital display screen. You then have to press a physical 'start' button to activate the function. If you do not press start, then the element does not come on.
If you're considering replacing the control unit yourself, then you will have to go most of the way towards diagnosing the actual problem with it. A stuck relay might just respond to a sharp tap on its case for example. I'm very used to prising these things open and looking for the problem but I appreciate not everyone is like-minded. Still, there would be several people I can think here of who would be more than happy to look at photos and try some remote sleuthing if you're interested.
I had it open today swapping out the PTC sensor and temperature limiter, so I don't have an issue opening it up.  It's a relatively quick job to get to the module so easy enough to try (can't help but think of the 2x2 shaped dent in the solenoid of my first car which required the occasional 'tap')
Phoned Siemens today, and should be able to get a remote diagnostic check tomorrow as its WiFi enabled.
OK good. Of course there may be no mechanical relays, it could be all solid-state. Blown triacs often fail short-circuit. Easy to spot with a simple multimeter. If remote diagnostics do reveal a fault it's odd your display doesn't report anything.
Phoned up BSH to request a remote diagnostic, to be told, we don't do that (even though their website says they do). However, the advice I did get based on description of fault was that it was either the element or control module.  Worth throwing the dice on a new element first, being considerably less expensive than the control module?
9 minutes ago, Stones said:
The culprit!
@ProDave - is this repairable / worth trying?
7 minutes ago, Stones said:
Control module replaced and all working.
I'm slightly confused. Did you replace the PCB but are now asking if the old one is worth repairing?
The soot looks like the fibreglass PCB might have been burning, possibly by a dry solder joint on the relay pins. If the copper traces are badly affected it won't be easy to re-solder. If it were mine I'd de-solder the relay and check its operation (it might be OK) and then clean it all up and see if the high current path can be reinforced with some solid copper wire when reassembling the relay on the board.
Yes, replaced the board. Marital harmony demanded a prompt resolution.
My question was really whether it was worth having a go at repair of the damaged board. It's 30+ years since I did any meaningful electronics so I'm a bit rusty.
I can't help wondering at the ultimate cause of the failure. Mass produced items tend to fail at the same weak points, like the old ABB inverters that all end up showing EO31 when a dry joint on a relay finally gives. I couldn't see if there was a hole in the side of the relay or not. It might be worth patching up and keeping as a spare. If not, I'd at least strip it for spare relays if any can be salvaged. Electrolytic capacitors (if not surface mounted) might also be worth keeping as spares as it's really only these and electromechanical parts that ever really fail.
What a neat hole! Never seen anything like that before. Presumably the PCB was vertical and the soot was rising with a flame? It's not for me to comment on that but how concerned are you about a repeat performance?
Yes, vertically mounted, and can only assume when it failed there was as you suggest, a flame.  None of the wires attached to the various pins had any damage (other than a couple with a little soot on the connector).
What is the likelihood of it happening again - not sure. Given the relay that failed only costs a few pounds, it may very well. Hopefully with a completely new control module/ board the risk of repeat is less.
In terms of fire, given there would appear to have been a small flame, I'm not sure what to think. The control board itself is.mounted on the back of the main body of the oven, and then covered by a metal panel, so in effect sits in a metal box.
