something to remove cement from granite
on one outside wall of the house there was a lean to pantry at sometime
this was hard cement plastered and tiled
 the lean to has gone ,but looking to remove the remains of the cement render from the granite walls
its real bugger to chisel off and I will never get it all off all over
 thegranite walls are not smooth in anyway
Edited by scottishjohn
I don.t know  if chemstrip would work
 or if it would eat the granite away as well
 or if it will take more than just staing off
 great if i could just paint it on and let it softenen al the old ceoment render  and then wire brush it off
I will speak to "sika " and see
10 minutes ago, dpmiller said:
if it's not a massive area, buy a small blasting gun and do it yourself. Slow and messy but doable
that will require a  large compressor and I do not have  power on site other than a generator --so will go with chemical attack first
9 minutes ago, dpmiller said:
spot/ small area guns will work off a 2 or 3HP pump OK. What depth is this cement? A needle gun would be an option too...
yes and that also needs a compressor --Iknow the one Iused have at work used about 10cfm --so small compressor would not do
the std calc is 4cfm per hp for compressors-and would need a fairly big tank to smooth it out
depth of cement render is up to 20 mm inplces --I,m sure they used the same granite sand as they did with the pointing -they would have any amount of it from crushing rocks
hard as hell---
