How do you support a 760mm ceramic sink? Help please!
Hi there
Have kitchen fitter on site and we have a 760mm ceramic sink to fit into an 800mm unit. Kitchen fitter is not sure how to create a frame to support this. He says that it is too heavy. The unit given is just a 800mm unit with 2 doors on the front. He said that it should have a different unit. Can anyone please advise. It can't be that difficult to build a supporting frame but fitter is saying he has never done before.
Please can you help- we thought this might be straight forward but clearly not! Thanks again!
Like you say, can’t be difficult. He is either inexperienced or not wanting to do something non-standard.
Photo or drawings might help someone come up with a solution.
Porthole. Should not be a problem for your kitchen fitter. By the sounds of things your sink should fit inside the sides of your unit. The legs on the bottom of your unit should be supporting your cabinet sides, so the weight should not be an issue. If your doors are full height then the top hinge hole will have to be re-drilled lower down. Thats not ideal but possible. If your doors are full height then you are going to have to set the sink back from the front in order to allow for a worktop (granite) front rail.  2x2 screwed into either side of the cabinet with an 18mm board on top, with a hole cut for the waste will be fine for support. Can you post a pic so i can see what sort of cabinet you have.
You have got to frame it at the top and have a supporting shelf underneath with cut outs for waste etc.  A s/s sink would just need the top frame.
My kitchen fitter wouldn't do the undermount sinks either - said it was for the Silestone guys.  Worktop lot said it needed to be in pre template.  Another scope gap needing to be filled by muggings here...
We used steel straps under the sink and fixed to the unit sides to support our sink after it was set in with resin. Just a steel sink but there's a heavy insinkerator hanging under it.
  • 3 weeks later...
