I am very behind with current build costs, and the last time I investigated them it was circa £800/m2 (budget self build) - £1400 (high end quality finish)
Given the rampant inflation associated with building material I suspect that these figures are way off in today's climate.   Does anyone have the current accurate figures?
Thanks
It’s very difficult to pin down costs
Labour is pretty stable now
Materials are more expensive But with massive differences between suppliers supplying the same materials
I noticed that Wickes have structural ply at £17.85 per sheet
Only a couple of quid dearer than what I’m getting it for at the saw mil
Buying 50 plus sheets at a time
Lots of companies are cashing in
You will need to do a lot of work yourself if you are looking to make significant savings
I’m still confident that we can come in at around 1000 m
Thanks.  I was absolutely shocked when I looked yesterday and saw moisture resistant 18mm * 600mm * 2440mm chipboard flooring at £22 a sheet!.  I nearly fell off my chair.   In 2007 when we refurbished our current property, I was paying circa £4 / sheet
Would be good to understand what products have been hit hardest by inflation.  For example, knowing that timber has gone up a lot, might change the design decision to use oak or cedar cladding to clad the whole upper floor of a contemporary build, and instead have to rethink or use an alternative material.
Edited by flanagaj
My builder says material prices are moving down, but his bricklayers asked to move from £180 a day to £250 after  many years together.
He ended the relationship and found new guys , but now has a fair bit extra work supervision etc
Generally a lot of materials are back to an “acceptable” level, many suppliers were taking the p%#£ during COVID restrictions but there was little justification for it.
but the runaway inflation is hitting pay rates and will cause more material rises if it isn’t deal with soon. If interests rates do not go up to a sustainable level many businesses will fail as they won’t be able to keep up with spiralling labour costs.
yes the heavily in debt businesses will suffer.
Our builder is not in debt , but as a design and build project, there is a risk that the factors you raise may hit my estimated costs . I will be in debt ….??
