I’ve got my new rads in, plumbed, attached etc etc.
I fill.
Tails leak.
I drain.
I re-do tails with 12 clockwise turns of PTFE (previous was 6 turns)
I fill.
Tails weep.
I drain.
I clean and re-do tails with a good smear Fernox LS-X and PTFE tape.
I fill.
5 of 6 fine (at 1bar, didn’t get to 2!) 1 horrendous.
I drain.
what next?!? More PTFE and more Fernox? Getting a bit pissed offed now. Not had this issue with other rads before. And obv no heating whilst it’s all off. Added pressure from SWMBO because she’s cold. Help!
Edited by CotswoldDoItUpper
SPG
21 turns of PTFE for me in most instances. You can tell if the threads are shit and the number of turns you’ve applied will not get any purchase, so if you’re a DIY’er then don’t beat yourself up……took me a couple of years to perfect this ‘sixth sense’.
Are you stopping turning the stem in before the last of the threads of the stem reach the rad?
Edited by Nickfromwales
Tiny amount of smear in threads on rad, 10 turns of PTFE Over three three tiny smears on the threads of the tail, keep PTFE nice and tight. Once done not full pressure for 48 hours
why do you nee 2 bar?
FYI, I have been fitting valves to rads for north of 25 years, and have never ( not once ) had to or would use Fernox ( aka clear silicone ) to make a rad valve off.
PTFE and experience is all you need, end of.
Fernox is a bodge.
Fernox is a bodge.
Gas PTFE for me.
We run to 2.5 bar cold on the day. If it can’t hold that we drain and redo. If it holds, we run it scorching hot and check again for final operation.
I fill.
Tails leak.
I drain.
I fill.
Tails weep.
I drain.
I fill.
I drain.
Some radiators seem to have the bores a bit loose  I have had this and needed to use hessian threads to seal them. Real pain in the ass tho.
Edited by Marvin
Ok so I’ve done 21 turns as per @Nickfromwales advice. Here goes…
they’re all from here: https://www.radiatoroutlet.co.uk/1800-x-383mm-white-vertical-traditional-3-column-radiator
tails/valves from screwfix. TRVs from Hive.
@tonyshouse I don’t need 2 bar, was just a check to see if they were holding pressure ok. Will pressurise properly when I know they work.
  • Like 2
Threaded joints?
Loctite 55 is more idiot proof than PTFE in my experience:
https://www.henkel-adhesives.com/lv/en/spotlights/all-spotlights/news/loctite-55-intro.html
Do make the wrapping tight. Don't make the wrapping too neat. Do "rough up" the threads. (scratch a file or hacksaw blade across them so that the outside of the threads feels rough) This will help the male thread "grab" the Loctite 55 and "drag" it deep into the joint. If the male thread is too smooth, especially with PFTE, then often the male part can "screw through" the PTFE as you tighten the joint so it looks like there's loads on but actually almost none of it is inside the joint.
IF DIY, paranoid, and not in a rush then fill cold, whack it up to the maximum working pressure of the components (usually 10 bar for radiators and taps), top it up again after the initial stretch is taken out, then leave it under pressure overnight using something like this:
https://www.ebay.co.uk/p/16028213862?iid=232209768745
That will find your weeping threads AND the compressions that you completely forgot to do up past fingertight / end feed copper that just has flux in but can hold up surprisingly well with just cold water at 1 bar or so!
  • 2 weeks later...
Update.
I’m giving up. I’ve put 30 turns on some and all followed all bits of various advice now. To the point where the olives are over compressed. Going to start again with new olives and nuts on these bad boys:
https://www.screwfix.com/p/bsp-male-x-15mm-compression-rigid-trv-extension-piece-65mm-2-pack/10954
hopefully the rubber o-ring will stop any leaks! Will still liberally apply PTFE as a belt+braces approach!
I used to use PTFE tape. Now I don't.
I push the pipe into the fitting and smear with Jet Blue Plus. I then push the olive up to the fitting. I then apply more Jet Blue Plus. Only then do I put the nut on. Wipe off the excess with a rag.
Haven't had a failure yet. Jet Blue Plus is even in my incoming water main joint that's at 8bar. It was the only thing that cured it leaking.
Some favour other alternatives Steamseal etc. I'd always check it's suitable for potable water.
https://www.wolseley.co.uk/product/center-center-jet-blue-plus-500-g/
25 minutes ago, dpmiller said:
so where is it leaking then- the threads on the rad, or the compression fitting on the valve?
I have 3 weeping slowly from the tails one of which is also weeping from the compression joint.
ugh.
Quick smear of vegetable oil on the O-rings to help avoid shredding them as you tighten up the fitting.
This is what loctite 55 looks like fwiw. Truly magical stuff.
Premium valves will come with pre 'roughed up' threads to grip string and drag it into the joint.
danfoss_randall_rlv-20_angled_lockshield_valve_003l014500_-_34.jpg.25ce49e9e1d9ed95e9f7afc06ad97479.jpg
The compression nuts on the are inverted. More like a brake pipe flare nut. It helps to keep the pipe "straight" in the fitting - the bore that the pipe runs through is much longer so it's difficult to stuff up the joint by waggling the body relative to the pipe.
I suspect your leaking compression will be caused by tweaking the valve body relative to the pipe as you fix it to the rad. Try to ensure that the valve body is held absolutely stationary as you tighten the compression. A smear of oil on the olive and the threads of the compression fitting will reduce the force that you need to apply on the spanners for the same joint pressure. This can help by making keeping the fitting stable easier.
