I'm going to have a suspended ceiling below these 2 steels.
So somehow I need to fix plasterboard ( or something ) to them .
How should I fix to the steel though?. I assume a timber batton is what I need. But I can't see drilling the steel to be fun ( also can only bolt from one side not the other ).
Presumably there's a standard method to do this????
TechFast screws are designed to fix light timber frames to steel and will self drill the steel. They take a Torx driver.
Even a girlie DeWalt cordless should be able to put them in ?
We did exactly this and used loads of them. Advice is to pre drill with a 3 or 4 mm bit as it helps these go in really easy
Yeah I struggled with these. I will pre drill a hole and test I think
19 hours ago, Mr Punter said:
Shotfire timber with Hilti gun.  Cheap to hire.
Have to look that up - but sounds fun; like a firearm - what could possible go wrong!
10 hours ago, pocster said:
Found some of these . So will give them a try . Says “ specialist “ on them - I am certainly special !
End is painted black so goto be good! Pre drill makes em perfic. I bought a big multi pack of cheap drill bits from screwfix or toolstation, all different sizes don't last that long but dead cheap and went through steel a fair few times before going blunt. Something like a pack of 100 for not much.
I used those Easy Drive screws to affix 9mm ply to my steel, wall hung Geberit frame. I didn't pre drill from memory.
20170812_145241
20170812_141535
39 minutes ago, redtop said:
Nooo, too much money for something that will blunt anyway. Go for these and chuck em when blunt. Erbauer Straight Shank HSS Drill Bit Trade Pack 150 Pieces | Drill Bit Sets | Screwfix.com
They are blue !
Also from previous experience. If I buy the cheaper option and struggle everyone will say it’s my fault for buying cheap crap . If I buy the expensive option and I struggle then it’s just me being crap .
12 hours ago, Simplysimon said:
if you're drilling steel, and i know you love the firm which comes in a fetching shade of black and yellow, buy their hss drill bits. https://www.ebay.co.uk/itm/154592266014?hash=item23fe6ac71e:g:HoYAAOSwn41hLqWK wouldn't buy their tools but these are superb
Purchased
Now I have EXTREME drill bits and SPECIALIST screws . If I did this for a living I could charge triple just because of that .
“Black and Yellow makes you mellow “  Mr.Dewalt
“Blue is poo “ Mr. Makitashite ( Japanese I believe )
Erbaur - similar to Fischer Price
3 hours ago, pocster said:
Purchased
Well if I knew you had money to burn ? agree the ones I listed are crap, but I was suprised they drilled well for a half dozen holes then its knackered. And they seemed to come with a shed load of 3 to 5mm sizes which were fine as pilot holes.
Use cutting compound when you drill and you'll at least double the life. A smear on hacksaw
& bandsaw blades helps there too.
3 minutes ago, Onoff said:
A smear on hacksaw
I usually end up with blood on mine
  • Haha 2
