Marvin Posted December 29, 2021 Posted December 29, 2021 Have been going through relay alternatives for my heating controls. Realised that some relays would be energised for hours and wanted to see how they coped. So here are my test results and questions. Thanks for looking. Equipment: Relays I'm testing: Results: My results based on ambient room temp 23C. All relays not under load. All relays 240v coils. BG CUC20 Watts when energised 2.2 steady. Temp after 10 mins 36C BETA Watts when energised 1.7 steady Temp after 10 mins 35C OMRCIT Watts when energised 4.7 to 4.1falling Temp after 10 mins 67C This one has a neon. Is the high temperature of the OMRCIT, when not under load, a concern? Bet you can guess which one cost the least.
ProDave Posted December 29, 2021 Posted December 29, 2021 I used Findr relay from CPC with a small plug in din rail base. I never measured the coil power consumption, but none seemed to get hot, certainly not 67 degrees hot. and they were less than £10 for relay and base. 1
Marvin Posted December 29, 2021 Author Posted December 29, 2021 (edited) 33 minutes ago, ProDave said: I used Findr relay from CPC with a small plug in din rail base. I never measured the coil power consumption, but none seemed to get hot, certainly not 67 degrees hot. and they were less than £10 for relay and base. Thanks for that. Anyone: If the coil resistance is 15.92 kiloohms and the voltage is 220 to 240, what is the Wattage? Is it about 3 Watts??? Edited December 29, 2021 by Marvin
ProDave Posted December 29, 2021 Posted December 29, 2021 2 minutes ago, Marvin said: Thanks for that. Anyone: If the coil resistance is 15.92 kiloohms and the voltage is 220 to 240, what is the Wattage? V2/R =3.61W Might be less as it's an inductive load on ac 1
Marvin Posted December 29, 2021 Author Posted December 29, 2021 1 minute ago, ProDave said: V2/R =3.61W Might be less as it's an inductive load on ac Your reply is near enough for me. Thank you. The "hot OMRCIT ones" were from china. The Beta ones I have had for some time.... The heat in the OMRCIT ones travels along the connectors to the terminals where the cables connect and I have measured over 70C just sitting on the kitchen side! Shut in a steel box with several in a row, with a load crossing the terminals, I think they would rise even higher and may melt the wire sleeving, even using heat resistant wire, so I am not going to use them, especially when they could be energised for hours at a time!
Temp Posted December 29, 2021 Posted December 29, 2021 5 hours ago, Marvin said: OMRCIT Watts when energised 4.7 to 4.1falling Temp after 10 mins 67C This one has a neon. Is the high temperature of the OMRCIT, when not under load, a concern? Is it possible the neon is fooling the IR monitor or does it feel that hot to the touch?
SteamyTea Posted December 29, 2021 Posted December 29, 2021 Anyone done a similar test on solid state relays? 2 hours ago, Marvin said: what is the Wattage Print this out and keep in back pocket.
Onoff Posted December 29, 2021 Posted December 29, 2021 10 minutes ago, SteamyTea said: Anyone done a similar test on solid state relays? Print this out and keep in back pocket. Or get the T-shirt / mug.
Marvin Posted December 29, 2021 Author Posted December 29, 2021 29 minutes ago, Temp said: Is it possible the neon is fooling the IR monitor or does it feel that hot to the touch? No. This was the bottom plate temperature. Hotter than the rest of the relay, measured up through the surround.
Radian Posted December 29, 2021 Posted December 29, 2021 52 minutes ago, SteamyTea said: Anyone done a similar test on solid state relays? Never really considered it. Opto coupler LED is nearly always the only load on the control side so I would think 60mW max (3V@20mA)?
Temp Posted December 29, 2021 Posted December 29, 2021 2 hours ago, Onoff said: Or get the T-shirt / mug. or just remember V=IR P=IV and work the rest out in your head ?
Onoff Posted December 29, 2021 Posted December 29, 2021 2 hours ago, Temp said: or just remember V=IR P=IV and work the rest out in your head ? Being pedantic... With a relay coil shouldn't R be substituted by Z?
SteamyTea Posted December 30, 2021 Posted December 30, 2021 7 hours ago, Onoff said: With a relay coil shouldn't R be substituted by Z Don't forget J and K
ProDave Posted December 30, 2021 Posted December 30, 2021 14 hours ago, SteamyTea said: Anyone done a similar test on solid state relays? They DO get hot, that's because they have a finite non zero "on" resistance so there are losses proportional to the load drawn. The SSR for my solar PV dump is attached to a reasonable size heat sink and gets just pleasantly warm at full load.
Temp Posted December 30, 2021 Posted December 30, 2021 23 hours ago, Onoff said: Being pedantic... With a relay coil shouldn't R be substituted by Z? Only for a little while ?
Marvin Posted December 30, 2021 Author Posted December 30, 2021 (edited) 14 hours ago, ProDave said: They DO get hot, that's because they have a finite non zero "on" resistance so there are losses proportional to the load drawn. The SSR for my solar PV dump is attached to a reasonable size heat sink and gets just pleasantly warm at full load. Yes. Hense the higher the power to energise the hotter it gets. .. Edited December 30, 2021 by Marvin
