James94 Posted November 3, 2021 Posted November 3, 2021 Just recently bought from here, couldn’t find anywhere in the uk to match prices. https://www.daemmstoffhandel.de/Shop_neu/gx2/en/category-6/ Regards. James
riboid Posted November 12, 2021 Posted November 12, 2021 I've spent so much on insulation and everything that goes with it, not sure if I'll ever recover the costs from a thermal improvement point of view, but, we have assembled a house not only for us, but for future generations too. Good job.
Iceverge Posted November 12, 2021 Posted November 12, 2021 Energy savings are obviously one aspect. Don't forget the thermal comfort aspects and the protection of the structure you're achieving. Payback only on energy costs are a very narrow window through which to view thermal upgrades.
Adsibob Posted November 13, 2021 Author Posted November 13, 2021 9 hours ago, Iceverge said: Don't forget the thermal comfort aspects and the protection of the structure you're achieving. This is what I keep telling myself when I see the big hole in my finances caused by a hell of a lot of Steico wood fibre products.
SimonD Posted November 13, 2021 Posted November 13, 2021 19 hours ago, Iceverge said: Payback only on energy costs are a very narrow window through which to view thermal upgrades. How I wish more people saw it in that way. Couldn't be more true. It's also healthier and provides a much more pleasurable and comfortable environment to be in, providing it's done right of course. I personally think that due to their mostly passive nature, thermal upgrades are cheap for what you get. 1
cwr Posted December 19, 2021 Posted December 19, 2021 On 28/10/2021 at 09:38, Iceverge said: A primer is the correct choice. Tapes need a dry and very importantly dust free surface to stick to. Masonry is rarely this without a primer. Is the expensive primer from the tape manufacturer required though, or are there cheaper primers/methods of preparing the substrate? I'm looking at the Winflex-I which needs PHS Ottello Adhesive Sealant to bond to block work, which itself needs a primer. Suspect this may be the cheapest option. Alternative I'm considering are the Isocell Airstop products, or Pro Clima Contega Solido SL though I'm unclear if the latter requires a primer.
cwr Posted December 21, 2021 Posted December 21, 2021 On 27/10/2021 at 14:58, Declan52 said: The tape I used from gerband required a type of glue that you applied like silicone into y the block work. It was a flexible adhesive and very very sticky. https://passivehousesystems.co.uk/product/winflex-i-airtight-window-tape/ https://passivehousesystems.co.uk/product/gerband-fortax-6400-airtight-sealant/ Hi Declan Roughly how much adhesive did you use per roll of tape? (Or rolls of tape per tube of adhesive).
Declan52 Posted December 21, 2021 Posted December 21, 2021 2 hours ago, cwr said: Hi Declan Roughly how much adhesive did you use per roll of tape? (Or rolls of tape per tube of adhesive). I reckon I got maybe 5m of a bead from a tube. This was mainly due to the rough texture of my lightweight blocks. If your blocks are smoother with not many holes then it will go much further. On blocks I cut the nosel much wider compared to when I had to stick the tape to concrete on the back of my window cills. Maybe talking at least double the amount of adhesive coming out of the tube on rough blocks compared to smooth concrete.
cwr Posted December 21, 2021 Posted December 21, 2021 Thanks Declan, that's good to know. So gonna need a lot of adhesive... I wonder if a parge coat would help reduce the amount needed much.
Andeh Posted December 22, 2021 Posted December 22, 2021 So all these products are to seal the gaps between window & masonry? Is there a reason gripfil or silicone is not used to plug these gaps up? They could surely achieve a similar result & are much more readily available?
Declan52 Posted December 22, 2021 Posted December 22, 2021 1 hour ago, Andehh said: So all these products are to seal the gaps between window & masonry? Is there a reason gripfil or silicone is not used to plug these gaps up? They could surely achieve a similar result & are much more readily available? They aren't flexible. As the walls shrink a tiny bit this adhesive will allow the tape to move so you won't end up with cracks at the joins and in turn air leakage. They are also very very sticky. You will understand when you get it in your hair!!
Declan52 Posted December 22, 2021 Posted December 22, 2021 8 hours ago, cwr said: Thanks Declan, that's good to know. So gonna need a lot of adhesive... I wonder if a parge coat would help reduce the amount needed much. That might be a decent idea as it's only the window and door revels that need some so not really a lot of mix needed.
Iceverge Posted December 22, 2021 Posted December 22, 2021 It's tempting to substitute airtightness products for others when you're building. The difference is only apparent months later. The flexible airtight sealent I used, (blue from a sausage) never really truly sets. Its like chewing gum, nasty if you get it where you don't need it or try to remove it. My brother looked over the scaffolding one day and declared it the worst thing he'd ever worked with such was its limpet like adhesion. Also for airtight tape. It seems to completely weld itself to any well prepared surface. Not instantly, but after a few weeks trying to remove it is almost completely impossible. I was so convinced I used it to seal our shower tray and bath. No leaks so far. I'm sure someone will tell me off.... 2
cwr Posted January 11, 2022 Posted January 11, 2022 @Declan52 did you buy direct from Passive House Systems? They're telling me they don't post to NI...
Declan52 Posted January 11, 2022 Posted January 11, 2022 48 minutes ago, cwr said: @Declan52 did you buy direct from Passive House Systems? They're telling me they don't post to NI... https://passivehousesystems.ie/ Try their Irish website.
Iceverge Posted January 12, 2022 Posted January 12, 2022 @cwr Try Philip @ https://www.prodomo.ie/ in Tralee. I think he posts to NI. I bought all my airtightness items there. I thought the prodomo own brand stuff was better than the belgacoat stuff i tried too.
