Triassic Posted October 9, 2021 Share Posted October 9, 2021 I’ve got my self install Panasonic ASHP up and running, however I have two ufh zones, one in each wing of a L shaped house. Each zone is supplied via its own manifold and integrated pump. I’m wondering what’s the best way of controlling each zone, I assume a simple room stat, but do need something programmable? I’m thinking Not? Do I rely on the ASHP time program? Link to comment Share on other sites More sharing options...
joe90 Posted October 9, 2021 Share Posted October 9, 2021 (edited) I remember our Jeremy Harris building his own weather compensation programming but ultimately dumped it fir a simple room stat. I like simple (less to go wrong). I run mine from a simple room stat with a small hysterisis mounted in the hallway, no zones but run the lounge at a slightly higher flow rate (as this is the room you tend to sit still in the most). The stat has timeing built in but never use it. House one temp 24/7. Works fir us. Edited October 9, 2021 by joe90 1 Link to comment Share on other sites More sharing options...
Triassic Posted October 9, 2021 Author Share Posted October 9, 2021 (edited) 24 minutes ago, joe90 said: The stat has timeing built in but never use it. House one temp 24/7. The plumber recommended expensive programmable room stats, but I’m left thinking the program function would be useless! As the ASHP would be the better control, with simple stats switch8ng on the zone p7mp as required. I assume you control your heating via the ASHP controllers, for both on/off times and temperature? Edited October 9, 2021 by Triassic Link to comment Share on other sites More sharing options...
joe90 Posted October 9, 2021 Share Posted October 9, 2021 16 minutes ago, Triassic said: I assume you control your heating via the ASHP controllers, for both on/off times and temperature? No, the ASHP programmer is sooo complicated I gave up (even with Jeremy’s help as he had the same ASHP and controller) Ours is on 24/7 (UFH) the ASHP heats an 80litre buffer tank controlled by a stat on the tank set to 35’. Our ASHP only heats water to one temp (and we set that to 48’) for both DHW and heating. The room stat calls for heat and this switches on the pump on the manifold. The manifold temp is set to 25’. I switch the buffer tank off during the summer by a switch giving open cct on the buffer tank stat. Perhaps not a Normal set up but it’s simple and works. 2 Link to comment Share on other sites More sharing options...
Triassic Posted October 9, 2021 Author Share Posted October 9, 2021 Looking at room stats, they are either old fashioned, simple manual dial, or all singing and dancing digital. All I want is a modern looking thermostat to switch the heating on and off! Link to comment Share on other sites More sharing options...
dpmiller Posted October 9, 2021 Share Posted October 9, 2021 There are basic digital stats too, but if you're thinking about zoning then it's a no-brainer to go programmable... Link to comment Share on other sites More sharing options...
Triassic Posted October 9, 2021 Author Share Posted October 9, 2021 1 hour ago, dpmiller said: There are basic digital stats too, but if you're thinking about zoning then it's a no-brainer to go programmable... Programmable not required. Link to comment Share on other sites More sharing options...
ProDave Posted October 9, 2021 Share Posted October 9, 2021 I am another one that shunned the ASHPs programmer as WAY too complicated. So that is set to 24/7 and just used for setting and reading parameters. I use a bog standard 3 channel central heating programmer, something that just about anybody knows and understands and feels comfortable with. 3 channels heating downstairs, heating upstairs (bathrooms only) and Hot water. Below that is simple room thermostats so 3 downstairs and one in each bathroom. 1 Link to comment Share on other sites More sharing options...
joe90 Posted October 9, 2021 Share Posted October 9, 2021 This is the one that I got from Wunda. https://www.amazon.co.uk/Underfloor-Heating-Programmable-Electric-Thermostat/dp/B07C15QQY3/ref=asc_df_B07C15QQY3/?tag=googsh Link to comment Share on other sites More sharing options...
Triassic Posted October 10, 2021 Author Share Posted October 10, 2021 15 hours ago, joe90 said: This is the one that I got from Wunda. https://www.amazon.co.uk/Underfloor-Heating-Programmable-Electric-Thermostat/dp/B07C15QQY3/ref=asc_df_B07C15QQY3/?tag=googsh The one you linked to is for electric UFH, not wet UFH. Link to comment Share on other sites More sharing options...
joe90 Posted October 10, 2021 Share Posted October 10, 2021 This from the Wunda website which is the one they supplied https://www.wundatrade.co.uk/shop/home/quick-shop/wundatherm-quick-shop/controls-quickshop/touchscreen-thermostat/ 1 Link to comment Share on other sites More sharing options...
epsilonGreedy Posted October 10, 2021 Share Posted October 10, 2021 @TriassicWhat EPC score are you expecting? What is the internal floor area of your property? I ask because you need to know how similar your situation is to the homes of those offering advice. @joe90's house is not far off a passiv standard and is sub 2000 sq ft hence running 24/7 off a single themostat works for him. Link to comment Share on other sites More sharing options...
Triassic Posted October 10, 2021 Author Share Posted October 10, 2021 My house is also Passive house and around 330m2. However, we’re only discussing room stats and I’m very much into KISS. Im happy to discuss room stats,or anything else house related, with @joe90 as his approach is something I can relate to and if I make a mistake it’s only going to cost me £30! 1 Link to comment Share on other sites More sharing options...
Triassic Posted October 10, 2021 Author Share Posted October 10, 2021 Having said I want something simple in a room stat, has anyone used Google home / Alexa compatible stats? Are they simple to set up and use? Some of the stats will be used to control electric UF heating in guest bathrooms. I was thinking we could ask Alexa to turn them on and off as required, without having to going round and re-programming each one. Link to comment Share on other sites More sharing options...
Alexphd1 Posted October 10, 2021 Share Posted October 10, 2021 Our plan is a operating a few zones in a similar size to you trissac, but with modern looking all singing stats operating in a dumb mode ie basic roomstat. Link to comment Share on other sites More sharing options...
epsilonGreedy Posted October 10, 2021 Share Posted October 10, 2021 2 hours ago, Triassic said: I was thinking we could ask Alexa to turn them on and off as required, without having to going round and re-programming each one. I can imagine the conversation now... You: Alexa give the heating a 2 degree boost. Alexa: Sorry Dave (err I mean Triassic) I cannot do that. You: Alexa why? Alexa: I have been reading the BuildHub forum and have concluded you do not understand passiv house heating principals. To boost the temperature in a meaningful timeframe my COP would drop to such a low factor it would endanger the planet. You: Alexa order a cheap wall thermostat from Amazon. Alexa: Sorry Triassic I cannot do that. Link to comment Share on other sites More sharing options...
Triassic Posted October 11, 2021 Author Share Posted October 11, 2021 (edited) @epsilonGreedy. You clearly don’t understand my wife! If she wants UFH in the bathroom so she has a nice warm feeling in her toes in a morning, she gets UFH and I get an easy life. our House I’d so well insulated we don’t have the heating on for more than six weeks a year. However, having fitted heating I’d like to have some control over it, even if that is to simply switch in on when we have guests, so that they to have that warm toe feeling. Edited October 11, 2021 by Triassic Link to comment Share on other sites More sharing options...
