Looking for some advice on what would be the best material and way to insulate these. Looking at the build up I have about 25 mm this includes the skim coat, this will take it to about halfway across window frame and I wouldn’t want to go any further than that.
Regards. James
There is a little, wasn’t sure how much ld need to prevent cold bridging. Was thinking some sort of material over the full triangle area to prevent to much heat loss in rooms.
This problem is the main reason I did not want dormers on my build, aesthetically i like them but well insulated dormers can be very chunky and ugly. Although a cold bridge it’s not a huge area
Was looking at the aerogel but I have six cheeks to do and that stuff is very expensive, was hoping for something a little cheaper.
Trying to find 12mm celotex near me and in stock not a chance. Been looking at XP’s and other makes of thin foam some on amazon and tile places,as you say anything is going to give it better protection.
Regards. James
So with this there is no need for plaster board? Plaster straight to it. Have you had any experience using this material and have you any links to it, wouldn’t want wrong stuff so many likeness/ copies of things nowadays.
 Regards. James
No experience with this., just seen it online.
You can defiantly render onto it directly, with breathable plasters and paint ideally,althought you might be ok with conventional materials given the placement in the structure.
