I urgently need a small quantity of clip track. I thought I had over ordered but think I have come up half a dozen short. If anyone has some left over from their install near South Cambridge it would be awesome if I could buy it off them. I've been using the Wunda clip track, but as long as it is for 16mm pipe and self adhesive it should be OK. It can't have barbs on he back for sticking into insulation. Thanks
Edited by MortarThePoint
6 hours ago, Temp said:
Not sure if this is 16mm? May need gluing down as no barbs.
https://www.screwfix.com/p/jg-speedfit-jgufhrail-clip-rail-2m-16-pack/51541?tc=MA3
This is likely to be 15mm being jg-speedfit
Ambiente UFH, based in Hatfield, Hertfordshire hold cliprail in stock with adhesive backing and no barbs.  It is strictkly for 17mm but i know it is tight for that size of pipe and i expect 16mm will be fine. - www.ambienteufh.co.uk
Amazon have sticky back for Wednesday and Screwfix is 24-48 hour unfortunately. The JG-Speedfit is 15mm. Ambiente may be an option. But time isn't on my side to head to the other side of Hatfield. Fingers crossed.
Wow, that was close. It came down to having less than two rails to spare and I feel I put it in everywhere it was needed.
I also worked out that you can ream the Nu-Heat 14mm clip rails out to 16mm using a 16mm forstener bit.
Thanks for the suggestions, but looks like I'm good and the screeders are now doing their thing. Pressure test was started last night at >9pm.
ooops replied waaaay too late, glad you're sorted...
Edited by Wil
