Slinky trench typical example 10m long produces about 1kw so 4kw equals 40m trench. However spacing between trenches 5m apart. So 200 square meters for 4kW
Single pipe down a trench about 15w per meter. Trenches about 1.2 meters apart. So 4 kW about 400 meters square?
All as rough numbers depending on lots of factors but you get the gist.
5 minutes ago, Russell griffiths said:
Bore hole, takes up 150mm square.
Yup. Assume your talking about a closed loop system. And costing about 30k
https://www.imsheatpumps.co.uk/
On their Web site ( you have to search ?
Answer: A 6-8 kW horizontal ground source heat pump system usually costs around £10,000 to £12,500 to install. A larger 12kW horizontal ground source heat pump system would cost around £15,500 to £17,500 to install. Vertical ground source heat pumps are more expensive due to the drilling of boreholes, so the equivalent 12kW system would cost around £30,000 to install.
Hope this helps.
My inclination would be to go with the larger collector to give the thing access to as much heat as possible.
Can't you use a wide enough bucket so that you get a straight pipe down each side of the trench?
