Young trees - removal options?
We have around around 25 juvenile trees on the site that will need to be removed in order for the house to go in:
They are a mostly different types of Birch with a few Goat Willows and Cherries in the mix. I estimate they were planted roughly 10 years ago and are currently around 15 feet high but the trunks are still < 6" in diameter.
What's the most cost effective method of getting these removed? I'm happy to relocated them to another part of the plot or even give them away if someone wants a grown tree for their garden!
If you want the cheapest option.
Get the groundwork guy to dig them out and chuck in a heap and wait for November the 5th.
However a nicer option would be to get the groundwork guy to dig them out with his biggest bucket and move them to another part of the site.
Option 1. two hours work.
Option 2. 6 hours work.
Bear in mind if you wanted to go to go and buy them at the end of the build you have a few thousand pounds worth there, so worth a punt moving them even if only 30% survive as it’s completely the wrong time  to do it.
Edited by Russell griffiths
I had several like that on our plot.  To remove them. I loosened around the base wit the digger, before then using the digger to pus the tree over and tear it out of the ground.  They then all got cut, dried and used as firewood.
Thanks everyone, I'll look at a mix of:
  • Giving away
  • Relocating
  • Cutting down for firewood and fence-posts
Really needing to watch every penny here after it turned out that getting services in will end up eating 10% of our budget.
If those are about the size I think they are (~20 ft?) then a birch will reach that size in a very small number of years, so personally I would not pfaff with transplanting.
The most environmentally friendly was to remove them is with a medium sized elephant.
Very useful things, elephants.
? I'll put up an ad for elephants in the local papers...
2 hours ago, Russell griffiths said:
Birch will be no good for fencing, it will only last about 2 years once cut.
Good to know - thanks!
