We are having a 32mm MDPE mains supply fitted and SES our water supplier does not allow any fittings before the shut off valve. Are plastic valves suitable for this? I found one source that suggested they were not.
Nothing wrong with plastic / ABS type stop valves, they are essentially what is in the bottom of every isolation chamber on every street. Just buy decent quality.
Well technically of course they are fine but our new connection Southern Water insisted it had to be a brass stop cock, wouldn’t consider anything else.
  • 5 weeks later...
Thanks for all the replies. We spend ages looking for a valve with for 32mm MDPE inlet and 28mm Copper outlet with compression fittings, then found out that Plasson make a compression copper adapter set so you can fit a 28mm copper pipe to a 32mm MDPE compression outlet.
Our supply pipe installation has now been approved by our water supplier
  • 1 month later...
PI - I am about to purchase exactly the same configuration. Did you go for plastic or brass? Any thoughts on plastic vs brass?
I'm about to do mine too 32mm MDPE to 28mm copper. @PI build do you have  links to the products you purchased please? Or anyone who has done the same please.
Any links to double check valves in 28mm also appreciated please - all I can find are 22mm from Screwfix (not sure what "DZR" means???).
I did this.
32mm mdpe to 28mm copper , used a talbot adaptor, push for on plastic and compression on the copper. To be honest can't remember where it came from but it can't have been too hard to get hold of as it's not etched in my mind.
If memory serves I either swaged the olive on using a normal fitting first, it soldered it, rather than overstressing the plastic, but I always overthink everything.
I ran 32mm to the road, but then the boundary box and tapping on the main was only the standard 25mm.
That was 10+ years ago, today I'd most likely just get the speedfit one from screwfix. Item 33399
Edited by JFDIY
The brass alloy is resistant to corrosion caused by zinc being leached by Chloride ions. (Google 'DZR brass')
@A_L looks like it is compatible with sea water then ? (with other benefits I now know). Thank you.
1 hour ago, JFDIY said:
I did this.
Thank @JFDIY so you connected to 28mm copper, have a 28mm brass stop cock then 28mm double check valve?
Yes, it's been in 10+ years, not sure if modern regs differ much, but I know the water board wouldn't come out until my stop tap was fitted so they could check it all.
I thought it was un-necessary at the time as it was little more than a stable block (conversion) with services in. I wanted to leave it isolated at the boundary box until the internal fit out was well underway.
  • 3 weeks later...
Hi Hilldes,
Just noticed you referenced my post, we got the parts from City Plumbing. Stop cock looks like this:
Still waiting for SES to connect us to the water main. I think we are at the bottom of the queue as they are connecting for free to bypass the existing lead pipe.
