March 22, 20215 yr Author Just now, Mr Punter said: Don't get a macerator, get a small pump station. That’s what the cubic 1 thing is . But it’s massive in size and cost !!
March 22, 20215 yr Author Think SWMBO now accepts sewage pumping is largely impossible in this situation. So the washing machine will go where the WC would of gone ? Assume for grey water appliances distance from the actual saniflo unit is not an issue ( i.e. washer will be around 3m away ). One less job for me now!
March 22, 20215 yr 2 hours ago, pocster said: But jubilee clips worry me. Why? Have you actually had one work loose before, or is it just a fear it could happen? They work on cars no problem... stay put for years, even with engine vibration, heat cycling, internal pressure etc.
March 22, 20215 yr Author 2 minutes ago, Gav_P said: Why? Have you actually had one work loose before, or is it just a fear it could happen? They work on cars no problem... stay put for years, even with engine vibration, heat cycling, internal pressure etc. Yes. On my pumps for drainage from the dungeon......... Went there oneday ; water spraying everywhere ... jubilee clip had failed....
March 22, 20215 yr 3 minutes ago, pocster said: Yes. On my pumps for drainage from the dungeon......... Went there oneday ; water spraying everywhere ... jubilee clip had failed.... Hmmm... unusual. I’ve only seen them fail if they have been incorrectly fitted or over tightened. But I can understand your dislike of them if you have experienced an accidental waterpark ?
March 22, 20215 yr Author 1 minute ago, Gav_P said: Hmmm... unusual. I’ve only seen them fail if they have been incorrectly fitted or over tightened. But I can understand your dislike of them if you have experienced an accidental waterpark ? Are you saying I balls'ed it up? Because that might be correct!
March 22, 20215 yr 5 minutes ago, pocster said: Are you saying I balls'ed it up? Because that might be correct! Of course not, I would never suggest that! ? You could replace the normal worm gear style with a T-bolt style.
March 22, 20215 yr Author 9 minutes ago, Gav_P said: Of course not, I would never suggest that! ? You could replace the normal worm gear style with a T-bolt style. What's that me old muckker?
March 22, 20215 yr Author 13 minutes ago, pocster said: What's that me old muckker? This ? https://www.orbitalfasteners.co.uk/categories/mild-steel-zinc-plated-t-bolt-clamps
March 22, 20215 yr 8 minutes ago, pocster said: This ? https://www.orbitalfasteners.co.uk/categories/mild-steel-zinc-plated-t-bolt-clamps Yeah, that kind of thing... you have to try really bloody hard to strip the thread on those, unlike the normal ones that can be over tightened quite easily.
March 22, 20215 yr Author 2 minutes ago, Gav_P said: Yeah, that kind of thing... you have to try really bloody hard to strip the thread on those, unlike the normal ones that can be over tightened quite easily. Ok ! I’ll get some . Then when/if it blows I can call you a (expletive deleted)
March 22, 20215 yr 2 minutes ago, pocster said: Ok ! I’ll get some . Then when/if it blows I can call you a (expletive deleted) get the stainless ones... zinc coated will rust over time.
March 22, 20215 yr 1 minute ago, pocster said: Ok ! I’ll get some . Then when/if it blows I can call you a (expletive deleted) Haha... no need to wait for that!
March 22, 20215 yr Just now, PeterW said: get the stainless ones... zinc coated will rust over time. Good point... especially in a dark damp basement !
March 23, 20215 yr Author Well it’s all plumbed up . Ran the tap . Macerator runs for about half a second and stops . Are my pipe ‘angles’ the issue ??
March 23, 20215 yr I don't think so. From memory, that pipe will be full of water. It won't pump air up behind it to empty the pipe. The pipe won't start to empty till it starts running downhill. Turn the tap on again, and i'm sure it will kick in. That vertical pipe will always be full of water.
March 23, 20215 yr Author 6 minutes ago, Big Jimbo said: I don't think so. From memory, that pipe will be full of water. It won't pump air up behind it to empty the pipe. The pipe won't start to empty till it starts running downhill. Turn the tap on again, and i'm sure it will kick in. That vertical pipe will always be full of water. You are right! I stuck my phone over the drain on record then ran downstairs and ran the tap ! Works like a treat ! I guess I was expecting it to be like a ? macerator I.e run on for 4 or 5 seconds . It’s surprisingly quiet . My final question is can I run a washer outlet and dishwasher outlet into the same pipe before going into the macerator or should they each use a seperate macerator inlet ?
March 23, 20215 yr 1 minute ago, pocster said: You are right! I stuck my phone over the drain on record then ran downstairs and ran the tap ! Works like a treat ! I guess I was expecting it to be like a ? macerator I.e run on for 4 or 5 seconds . It’s surprisingly quiet . My final question is can I run a washer outlet and dishwasher outlet into the same pipe before going into the macerator or should they each use a seperate macerator inlet ? You can run multiple outlets into the same unit fella. I sure that there is the potential for the pump to reach capicity, but with a couple more items only it will be fine fella.
March 23, 20215 yr Can i also just say. Nice bit of solweld Pocster. Much better than some of your previous efforts......(Sorry, coul'd resist)
March 23, 20215 yr 17 hours ago, pocster said: SWMBO has offered a compromise ( at least that's the wording she used ) No one will poo in this toilet! Can you imagine that?. Big sign on the wall "Don't poo in this toilet". All the grand kids come over and deliberately shit in it. Then probably take my sign and flush that aswell. Sigh!. I am doomed. So 2 macerators in the finished kitchen. One for grey water and one solely for the WC with only wee in it ( yeah right! ). The solution to your problem: You want a "toilet" that will never be used for a No 2, and can be connected via a long horizontal pipe with a slight fall, a but like connecting a sink. Answer. Install a Urinal.
March 23, 20215 yr Ozzie Osbourne has a Urinal in his gaff. I think they are great. Saves pi$$ing all over the floor.
March 23, 20215 yr Author 7 minutes ago, ProDave said: Answer. Install a Urinal. I even suggested that A urinal and a she wee
March 23, 20215 yr Author 18 minutes ago, Big Jimbo said: Ozzie Osbourne has a Urinal in his gaff. I think they are great. Saves pi$$ing all over the floor. What’s wrong with (sigh ) wee’ ing on the floor . Robot vac mops it up Edited March 23, 20215 yr by pocster
March 23, 20215 yr Author 20 minutes ago, Big Jimbo said: Can i also just say. Nice bit of solweld Pocster. Much better than some of your previous efforts......(Sorry, coul'd resist) Setting up my own plumbing firm “ Pocsters Plumbing “ or slogan is “ we will gladly plug your holes “
March 23, 20215 yr 4 minutes ago, pocster said: Setting up my own plumbing firm “ Pocsters Plumbing “ or slogan is “ we will gladly plug your holes “ I'd like to join. Happy to service the ladies, plugging holes.
