We are all find and dandy with the installation of the UFH but a bit confused over the preparation side of it.
Do we -
Lay a plastic membrane first (tape all the joints)
Followed by insulation (tape all the joints)
Followed by another plastic membrane (tape all the joints)
Followed by the UFH pipes?
Do we need upstands of insulation and are they encased in DPM too?
Our screed layer has sent us a diagram but he is mostly concerned that we tape all the joints.
Have looked on you tube but most videos are about the pipe laying and not the preparation.
Post the diagram you have and any information from e.g the architect about floor make up.  There is no single answer, many ways to lay UFH.
My technical skills for posting diagrams is zero :(
We have just looked at the detailed plans and it seems to show that there is -
a layer of dpm laid on the concrete slab..
Then there is a layer of insulation.
Then there is a layer of dpm again.
Then, we assume, the pipes go down. But surely this is not right? Should there be another layer of insulation for the ufh pipes to sit on?
The flow screed company has sent diagrams showing
DPM
Insulation
DPM
He is very keen on all joints being taped with the correct tape.
He has not shown another layer of insulation. Do we need it in order to lay the ufh pipes? And does the screed then get poured over pipes and insulation?
You need to get the detail right including enough insulation in the right places.  with UFH is is more important than a normal floor to get plenty of insulation.
Posting pictures on here is simple is is literally copy and paste them into a post.  You must have some drawings from the designer?
The second (top) DPM isn’t really a DPM. It is a slip membrane designed to stop the liquid screed flowing between the insulation blocks and floating them upward.
Tape everything and then pin the pipes down, tbh this is why I prefer the plastic trays as nothing moves.
Easy if you have a smart phone etc. I just use a laptop.
Ah that makes sense. It is a large bungalow and the trays would cost us thousands :(
Even easier on a laptop.  Find the picture you want, highlight it, press Ctrl C or right click and press copy.
Go to writing a post and press Ctrl V or right click and press Paste.
..??? how big are we talking ..?? They speed up the laying too so watch for savings elsewhere.
Not if you don't have the photo on there to start with :(  Society nowadays does not allow for those of us who don't have the skills to take photos and load them onto computers. Neither does society allow for those of us who cannot accept texts with codes that release our money or give us access to all sorts of other financial dealings.
The bungalow is 180 sq m and we are doing the plumbing and heating which makes the labour free.
Am I right, then, in thinking that we should lay the dpm followed by the insulation then another dpm with the heating pipes on top?
Get someone to show you after lockdown, its easy when you get the hang of it and very useful.
Have you thought about upgrading to a smart phone? They are pretty cheap secondhand
Not exactly but sort of correct...! Second top DPM can be a 300 gauge thin membrane as it’s only there to stop the screed going through under the insulation.
If you’re clipping down then it’s DPM - Insulation - Slip Membrane - pipes
Didn't I see something on tool share about the stapler thing which administers the clips to hold the pipes down?
Edited by Jilly
We get no signal here so it would sit totally unused.
  • Sad 1
Yay! Thank you :)
@patp Do you have any drawings from the architect or designer?  If you have them on your computer as some form of file pdf for example you can attach them to a post.
At the moment I still don't know if you have a solid floor built up off the ground?  Beam and block or timber suspended?  What the designer has proposed as insulation, how much and where?
Without this guessing where to put a membrane is meaningless.
If you can't post a picture or file, then describe in words how your proposed floor is constructed and what layers it has starting from the ground upwards listing every single layer, what it is and how much.
Nothing like that on computer. We have huge paper drawings though! they show what has been described above.
In words that is -
A solid floor built up off the ground. Than it shows a layer of DPM followed by a layer of insulation, then a layer of membrane.
The take off, that we had done by the builders merchant, shows this
Polythene membrane Blue Standard Duty 300mu 100 M2 x 2 rolls
Polythene Membrane Green tinted Standard 125mu 4 x 50m rolls x 1
Foil Faced Rigid PIR Insulation Board 2400 x 1200 x 20 mm x 4
Ready Mix Concrete 18 m3
Foil faced Rigid PIR Insulation Board 2400 x 1200 x 150 mm x 64
We have already laid one polythene membrane under the poured concrete floor. The walls have been built and the roof is on with windows due next week.
Hope this helps.
Ok I would use 1200 gauge below the insulation,  300 is very thin for a DPM.
The 20mm is edge insulation. 150mm below is good for UFH.
The 300mu is 1200 gauge so will be fine for DPM.
125mu is 500 gauge and fine for the separation layer.
  • Thanks 2
