Log burner help!
8904jo
Recently fitted a multi fuel stove.  Correctly installed etc by a certified fitter and had the chimney cleaned first.  New burn smell was horrendous first couple of days then subsided only to be replaced by a new smell.  When the stove is on the whole house smells of burning, not smokey as it doesn’t set off the carbon monoxide alarm or smoke alarms just pure burning/singeing smell.   Fitter came out and did smoke test but stove seemed fine but the company in question replaced it with a new stove.  Refitted, resealed all flus etc but a few days in and the smell is as bad as ever.  Not just as bad when burning smokeless coal but wood is horrendous.  The draw from the stove seems fine and the heat is amazing - just can’t enjoy it because of the smell!  Help please!
I feel for you. We had a new wood burning stove fitted in an old house and it had a very distinct smell when it was new, I cant remember how long for, but I guess that's not the 'burning' smell you are describing. Was a liner fitted at the same time? Did you have it swept before installation? Did the sweep notice anything? Can you identify the source of the smell? Is it from the stove/chimney/joints or even another chimney in the house? This wont be the whole answer but do you have a dampmeter to check you aren't burning wood >20% moisture? Or contaminated wood?
Hi thanks for replies.  House was built in 1996, one chimney.  Maybe should  have said we have been using an open fire with a back boiler and this was all disconnected professionally so don’t think there’s any issue there.  Impossible to identify where the smell is coming from.  We are burning new dry wood (husband is a construction site supervisor so plenty of offcuts).  Also have tried using smokeless coal only and smell is still there albeit not quite as bad.  We have a liner fitted and chimney was swept before installation
They almost all smell of burning paint when new because the heat is needed to fully "set" the paint.
As for smoke.. go outside and check where the smoke is going. Could it be lingering around the house and coming back in via trickle vents?
On 16/02/2021 at 08:46, ProDave said:
Type of property, old, new, how many chimneys, what air inlet ducts are there, what type of stove?
Hi all quick update.  We removed the baffle plate to check the chimney.  No smell in the house, fire burning straight up so the problem is definitely not the chimney! Problem is with the baffle plates in.  Any more advice would be appreciated.
