Olf Posted February 15, 2021 Posted February 15, 2021 No such thing as dumb question so I'll try: 11 courses of blocks = 2465 mm 1 standard plasterboard = 2400 mm 65 mm gap staring at me in the worst nightmares. Is the plasterboard aligned with the ceiling, with the gap at the bottom covered later by the skirting?
TonyT Posted February 15, 2021 Posted February 15, 2021 That’s how mass builders do it. you can of course put an off cut in too. 1
CC45 Posted February 15, 2021 Posted February 15, 2021 skirting to cover the gap. Tricky because the gap will need filling with something. Or cut a sheet to fit (avoid slivers of PB) - alternate the line so that the cracks don't go the length of the wall! 1
PeterW Posted February 15, 2021 Posted February 15, 2021 Closer to 50mm by the time you’ve got ceiling board on. You can also buy 2440mm or old 8fr boards. 1
Olf Posted February 15, 2021 Author Posted February 15, 2021 17 minutes ago, PeterW said: Closer to 50mm by the time you’ve got ceiling board on Ok, so with the floor finish taking another about 20 mm the gap becomes manageable - happy nights
tonyshouse Posted February 15, 2021 Posted February 15, 2021 Plasterboard is available in 2.5m sheets, 2400, 2440, 2500,2600, 2700, 3000 sheets
Temp Posted February 15, 2021 Posted February 15, 2021 1 hour ago, CC45 said: skirting to cover the gap. Tricky because the gap will need filling with something. Insulation perhaps?
tonyshouse Posted February 16, 2021 Posted February 16, 2021 Off cuts, foam, bonding plaster, anything airtight
PeterW Posted February 16, 2021 Posted February 16, 2021 11 hours ago, Olf said: 11 courses of blocks = 2465 mm This assumes your floor runs to perfect levels with blocks too. Other option is coursing bricks which give you flexibility to change the levels. Have seen them used to lower windows etc so you don’t need to split blocks.
Onoff Posted February 16, 2021 Posted February 16, 2021 Idiot that I am... I ended up with 2470mm, finished floor to u/side of joists. I bought 2700mm boards so a fair bit left over. As i put the new ceiling joist in anyway, all I had to do was lower them or counter batten and create a service void. Would have saved me so much grief in terms of silly tile rips at the ceiling, airtightness at the ceiling etc. Should have, could have, would have...
