Hi and all the best in 2021 (although I said the same last year and look how it turned out).
Does anyone have any experience with performance of sash windows at all? I was doing some reading about Georgian style house, which tick quite a lot of boxes for me. Easy shapes to build, symmetricity, simple roof, etc. However, I do wonder about sash windows. You can get some with very good U values but if they are not airtight, isn't it a false economy? Any real live experience or solutions? I have seen Mock Sash Windows but not really sold on them.
I am not building anything right now, just gathering knowledge :-).
Thanks,
Thanks,
Hi Nick,
This year i've installed Green Building Store timber sash windows on my new build, which I think look loads better than a lot of the 'mock' sash windows on the market. They score a class 3 on air tightness (out of max 4), this is with both top and bottom sash openers. I specified many of my windows as fixed, non opening and some with only one sash sliding. I am hoping that, having installed them correctly, I will still be able to achieve a very good air tightness score.
I’ve got unbranded upvc sash windows.
Positives:
look ok. Great variety of opening options. Nice and secure. Zero maintenance. RAL colour options. Easy to clean. Light weight to slide and tilt.
Negatives:
Crap for air tightness.
I wouldn’t have them again. But I guess you get what you pay for, they were cheap. In fact I am wondering if I should swap them out for more normal casement windows.
@willbish I have to admit that the Green Building Store mock sash windows just look odd but that is based only on pictures. It may be different in the real world. I hope airtightness will spot on for you.
@Gav_P You get what you pay for as with anything in life. I agree normal window is lot better but if we are talking Georgian Style, sash is almost non-negotiable.
Based on my experience, although they had a fairly decent u value (afaicr), any consideration to sash windows needs to focus on the draft proofing and tolerance between frame and unit.
6 hours ago, willbish said:
@NickK Apologies if I want clear. I haven't installed the mock sash but the sliding sash.
I love the colour. Really stands out. What are walls going to be?
7 hours ago, NickK said:
@willbish just out of interest, how much did your windows set you back? If you don’t mind me asking.
The porch window pictured above, as an example, was £785
My sash windows are from Bereco.
fitted them 14 years ago on the original house and 2 years ago on the extension
timber, prefinished decent spec
fitted With metal brackets and then foam around the gap, then tescon tape over onto the timbers- tape hidden by plasterboard and internal cill
  • 2 years later...
Sorry to resurrect this thread, would you still recommend these @TonyT? If you don't mind me asking, how much did they cost you when you last ordered some?
