Hi All,
My architect has specified 100MM PLASMOR FIBOLITE 3.6N BLOCK for the internal block work on my self build.
A few of the builders that have quoted have raised concerns on this type of block saying that they will crack.  I have had a few difficulties getting my SAP requirements and can see this opening up old wounds if I was to change this block.  Would any of you have experience with this block? Is there an alternative with similar u-values that is stronger?
Whilst looking at blocks I came across the Marmox Thermoblock for a single course to aid with thermal bridging.
http://www.marmox.co.uk/learning-hub/reducing-thermal-bridging-in-wall-to-floor-junction-designs
Has any one used these blocks?
Thank you
We used 3.6n Fibolite without any issues.
Ask the builders why they will crack and if they have used them before, are they confusing them with other blocks?
The Fibolite blocks are made with expanded clay beads.  They are not the aircrete crappy ones.
The Marmox are good for a single course.  Get your SAP person to let you know if they make any difference to your rating.
Hi All, thank you for the replies
Sounds like the builders were getting confused with the type of blocks, which is good news in a way!
Mr Punter, have you used the Marmox block?
Not yet but have spec'd it for a forthcoming project where we have to get a minimum 19% C02 improvement over part L 2013.  I was also looking at Foamglas but the Marmox looks cheaper and has higher compressive strength.
A lot of old school Brickies have been schooled to have the mortar far too strong for blockwork which can cause cracking-they then consider the blocks to be too weak without considering the mortar strength.
Thanks everyone. Looks like I'm ok with the Plasmor block.
Regarding the Marmox block, I have asked my SAP guy for his thoughts on how much difference they would make to wall u-values and my overall SAP.
Thank you Vee6 dan it's good to hear they are quite straight forward to lay and yes, just for one course
