Taff Posted November 13, 2020 Posted November 13, 2020 Rental home, Any ideas ? i now turn turn tap on that was working fine last night, so before I get the hammer ? out! Its now just a dribble of water coming out. All other taps fine.
bassanclan Posted November 13, 2020 Posted November 13, 2020 I presume it is cold mains pressure? Check under the basin in case someone has turned an isolation valve accidentally whilst cleaning etc
joe90 Posted November 13, 2020 Posted November 13, 2020 12 minutes ago, SteamyTea said: Stuck tap washer, get the tools out. don’t forget to turn the water main off first , or the isolator if there is one.
Taff Posted November 13, 2020 Author Posted November 13, 2020 Guessed it was a washer, there’s no isolation to the tap, it’s actually the hot the tap was for illustration. Anyone any idea of the brand or is it just generic
Taff Posted November 13, 2020 Author Posted November 13, 2020 15 minutes ago, joe90 said: don’t forget to turn the water main off first , or the isolator if there is one. Think the stop cock requires turning off ?
ProDave Posted November 13, 2020 Posted November 13, 2020 If it's a hot tap, there should be an isolating valve on the output of the hot water tank. You can also get a "stuck plunger" in some old taps.
Taff Posted November 16, 2020 Author Posted November 16, 2020 Sorted chaps new washer ??? ta muchness for help, AGAIN!
