Metal tracer, for plastic pipes
Evening all.
If installing plastic pipes in a wall is it a requirement to fit a metal trace wire or foil tape, so you can detect their location with a stud detector.
Think it might be an nhbc requirement?
Hi. Is the silver foil tape detectable when the pipes are pinned to foil faced pir insulation?
Just take pictures before boarding, with a tape held up for reference measurements. Pipes are usually in the centre of the stud void so you'd have to go out of your way to strike one. Prob best to stick the foil tape to the back of the PB instead of onto the pipe.
Whilst looking for info on installing wiring for a multi room speaker system I came across a thread on the avforums or similar.
You can buy NFC tags and stick them on anything and then once you need to find them just use your phone to locate. Seemed like a great idea...
