Blade cutting depth for track/plunge/circular saws?
MJNewton
I'm about to embark on a mammoth cutting session trimming down end panels, plinths etc for the new kitchen. I've bought a new 40T blade for my Titan track/plunge saw (it came with a 24T) but was wondering what blade depth I should be using for the best cuts?
I'm sure I saw a video one time suggesting the blade depth should be such that the teeth only come halfway through the bottom of the work piece, whereas another article I've just read (on circular saws - I am assuming its the same consideration) says to have the blade coming 5-10mm through. Most other discussions about track/circular saw use don't seem to mention it.
Any advice?
Sounds similar to what I read when I bought a plunge saw a while ago. I believe you want the depth to be such that the cutting edge of the tooth doesn't leave the lower surface of what you're cutting. For a typical blade, I guess that means you want the tooth tip to extend about 3 or 4 mm below the bottom surface.
Have a look at Peter Millard's YouTube videos on plunge saws. He really knows what he's talking about.
The less blade protruding the less force there is on the saw base plate.
This is a safety issue.
I set the depth to maximum as it 'pulls' the work piece onto the base plate better.
Do get a rougher cut.
Opps, thought it was a hand held circular saw you were using.
Edited by SteamyTea
Thanks for your thoughts; it does sound like an as shallow depth as possible is what's called for if I want to maximise neatness of cut.
Thinking back I think it could well have been one of Peter's videos where I saw the suggestion about having just an ever-so-slight protrusion of the blade beyond the bottom of the workpiece. As you say he seems to know what he's talking about so I'll go with that.
Edited by MJNewton
Contrary to advice I find in real world my tack saw produces less chipping on underside of cut the deeper it is. I find if I set it to a mm or so more than material the cut isn't always perfect. Set it to 10mm more and it is. I keep sharp blades too
Ah okay, that's interesting. Will try some practice cuts as you suggest.
I've only used my track saw for cutting up OSB sheets so haven't paid too much attention to the quality. Probably not the most representative of materials either.
There is no right answer for all materials, blade protrusion depends on the material being cut and the surface finish (thats the material itself, not splintering etc.)
General rule of thumb - unfinished chipboard and OSB full protrusion to clear the blade gullets of resin faster.
Melamine - approx 1/2 tooth. practice/test cuts is the only real way to be sure
My 36v Makita has a factory depth stop up by the trigger set so that when engaged it allows a 2mm cut into the face material. You then slide back, disengage the stop, and complete the cut.
DEFFO do NOT have the saw blade finishing on or just below the underside of the cut material. You need to have at least 10mm clearance to allow the teeth to cut upwards rather than cut forward, as the latter tears through and the former cuts clean through.
The blade being 40t minimum and new is beyond critical criteria for a good finish.
Edited by Nickfromwales
I was surprised how cleanly even the stock 24T blade cut, not least given I'd previously set the blade too deep such that it extended beyond the timbers I had the board supported on... I was wondering why it was so noisy - only afterwards did I discover I'd been cutting a 2mm deep score in the surface of the pristine screed below. I'm sure that didn't do the blade too good!
