Evening, just discovered the forum...
I have recently started a build project in East Devon close to the Exe estuary. A timber frame build, clad in cedar, lots of glazing to a South Westerley aspect, making the most of the view and solar gain, which will hopefully be controlled in the Summer by a 2m roof overhang...
For those of you that like time lapse videos I have some footage of work to date at
http://www.exe.holiday
I fear this forum will encourage project scope creep, I'm now investigating MHRV systems....
Guest Alphonsox
Welcome to the forum - that looks like a great spot for a build.
Lots of MVHR experience in these parts - please post any questions you've got.
Welcome - MVHR is a must if your build is airtight and you have windows without trickle vents etc. Above 2 air changes / hour (ACH) it won't work that well from a heat recovery pov but will still deliver fresh air and remove stale air.
Do you have any airtightness provision?
2 hours ago, Crofter said:
My MVHR quotes have been well under £1k, so it will cost less than my woodburning stove. Worth it for good air quality, IMHO.
Is there not a risk that the MVHR will draw in smoky air?
Not if the flue draws well and works properly ( not like the neighbour over on the GBF)?
9_9
Probably best to mention that your building the forums smallest house ;)
:D
Welcome aboard Jimbo. Check out the various threads that related to your enquiries and glean what you can. There is a hell of a lot of sound, impartial and honest advice here.....both the good and the mistakes, so strap yourself in and enjoy the ride :)
27 minutes ago, Nickfromwales said:
9_9
:D
Guilty m'lud... although the systems are sized for 150m2 as a minimum, so there should be economies of scale to be had.
IN this area .. Mansfield .. Jewsons specialise.
I have about 4 within a few miles, but only one of them has an extensive roofing selection.
Not sure what difference that makes to price.
