joe90 Posted December 30, 2016 Posted December 30, 2016 We are having UFH downstairs (only) with tiles and engineered wood flooring glued down. I know that tiles are good at transferring heat into a room and wood less so and I have told er indoors that we cannot have rugs on the lounge wooden flooring because of the UFH but I just know that she will be asking for a rug in front of the fireplace by the settee after we move in?. My question is can I negate this by leaving out the UFH pipes in this area ( like we are in the kitchen where fixed cabinets are going) or rather not can I but is it common for people to do it?, does it make sense? On the same theme, as wood is more of an insulator than tiles would it not make sense to use thinner wood flooring ( bonded down to concrete) to a/ save money, b/enable more heat to enter the room?
ProDave Posted December 30, 2016 Posted December 30, 2016 We have a rug in front of the fireplace with UFH and solid wood floor. No problem. Yes if you lift the rug it's a bit warmer under there but does not cause problems and noes not limit the heating in any practical way.
Onoff Posted December 30, 2016 Posted December 30, 2016 I'd leave the UFH under the rug area tbh. It'll transfer some heat still and be less complicated than routing the pipe round the area.
Temp Posted December 30, 2016 Posted December 30, 2016 (edited) Some engineered wood floor companies say no rugs to cover their backsides because there is a risk of the glue delaminating. However we've had boxes of books piled up on our wood floor with the UFH running quite hot and no problems. Edited December 30, 2016 by Temp
Nickfromwales Posted December 30, 2016 Posted December 30, 2016 +1. Fit the pipes, let swmbo have the rug of her dreams ( "operation peace 'n' quiet' ) and fit a substantial floor board without worry. One previous job I did had posi joists with UFH pipes in Alu spreader plates. 22mm weyroc over the joists, then 6mm ply, then tile adhesive and then porcelain tiles. The only complaint was it was too warm in there. Heat will find its way through, trust me, and the rug is a very small area . 1
ragg987 Posted December 30, 2016 Posted December 30, 2016 We have a large thick persian rug over 20mm engineered oak glued to the (liquid) screed - approx 50% floor area in that room is covered - no issues with heating the room. Slab is generally around 25-27 deg C (estimated).
joe90 Posted December 31, 2016 Author Posted December 31, 2016 Thanks one and all for your comments, I am obviously over thinking the issue ( best to get it right before it's too late tho?)
