Hi All,
We are having a standing seam roof on our house and are getting a few quotes in. I'm surprised at the amount for installing the roof, it's quite large 240m2 but they are all around £8000+vat for fitting. I know it is difficult to say, but how long does it take to fit a standing seam roof on a detached house?   My logic is 2 people over 5 days at £250 = £2500 , will it take a lot longer or are day rates a lot more?
Unfortunately there prices won’t be worked out on man hours
If building was less busy You would see the rates drop
I only have experience with Catnic/Tata and it does not take that long to be honest. Putting the panels down is easy, if it is just a straight up and over detached roof with no hips/valleys then you could finish that in a day easily. The setting out and doing the edges, starter panel and ridge detail a bit longer but nowhere near £8000 worth. I went on the day course with Tata and saved a small fortune  by doing it myself.
  • Haha 1
@PeteI've just finished putting a box profile roof on my sheds, that was bad enough, I'm great with heights so I give doing it my self a miss :(
11 hours ago, Russell griffiths said:
I would say the price in the first post is about right.
I had a quote of £12,000 to fit 350m so about £35 a M.
Is the £12,000 just for installing and not the materials? if it so is in line with mine.
what material are you using? I've found the time is really in all of the verge/gutter/facia details rather than just the main roof covering, do you have rooflights etc too?
Yes you are right, I did not have any rooflights
About £35 a meter for materials, and the same for fitting, I did mine myself and saved a big chunk.
I used metal solutions, ask for Kevin tell him I sent you, I was originally going with Tata / catnic until I found metal solutions.
@the_r_sole The quote for materials was for coated aluminium, I was quite happy with that. I do have 8 roof lights and there is a dormer plus a number of verges and ridges  so it is quite complicated, I was just a little surprised about amount.
I'm going to use standard plastic eaves and soffits to help reduce costs.
If the installation cost is quite standard, then I will go with it.
Thanks
I think you will be surprised at the amount of work, it is certainly not a small job.
Make sure you have your details right around those windows so they don’t clash with a seam.
Houses near me that have lots of roof windows have custom width sheets around the windows.
@Russell griffithsYes it was the initial shock of the price, but works out aorund £30 - 35 m2 which is about the going rate.
I think we will be in the position to specify the roof lights to fit the panel widths.
I'm getting a lot of shocks lately, I already have a glazed gable end wall with bifolds, just had new quote in for some more glazing, I knew it would be a bit more but not four times the cost :(
I have quote for £57/m2 supply and fit.  This is based on a fairly small area of 13m2.
Edit: Oops completely misread as "Sedum"!,  so that £57/m2 is for Sedum roof, sorry!
Edited by Dan F
  • 2 weeks later...
  • 2 years later...
Hi. Does anyone have a more up to date cost for installing standing seam metal roof? The cost of everything has gone up so much! Many thanks
