I bought a chrome bottle trap with my sink from a company called Durovin on eBay. They are quite a big company and do lots of basins. Its way too late to return now but I am just coming to fit the trap and the pipe size coming from the bottle to go into the wall seems an odd size.
In the wall I have 90 degree standard 32mm solvent weld fitting facing out the wall. Onto this I was going to fit a 32mm solvent weld to 32mm compression fitting. In the UK I believe the 32mm size refers to the internal bore diameter of the pipe, so standard compression fittings have about a 36mm hole to allow for the thickness of the pipe.
However this chrome pipe which came with the bottle trap has a 32mm EXTERNAL diameter so when you put in a 36mm hole its far to loose to use.
Is this how they are meant to come or are they meant to have a 36mm external diameter on the Chrome pipe as well? Anyone seen a fitting which I might be able to use for this?
Thanks
Have you shortened the pipe?
I have just had a look at mine and measured it.  The chrome pipe, where it exits the bottle trap measured about 32mm OD.  But at the end, it flares up to a larger diameter that I measured as 35mm and that nicely fits a "32mm" compression fitting.
Here is one picked at random from ebay to show how the pipe flares up at the end to a bigger size
https://www.ebay.co.uk/itm/Chrome-Plated-Bottle-Trap-BNIB/283898803468?hash=item4219aff50c:g:mrwAAOSwK4pey8BS
Thats interesting.
The one I got with the trap is just a straight 32mm, no flare. I just measured both ends again to be sure.
Maybe I can find just the pipe to buy then. I haven't cut it, this is how it came. Also the chrome cover which goes on the wall where the pipe enters it only has a 32mm hole in it so would need a new one of those too.
Have you tried a 32mm push fit fitting, they are smaller than solvent weld.
I would have thought a compression type joint would have worked, if not as pretty
Not tired this but as they are still 32mm internally, and the pipe I think is still 34mm externally might still be a little loose. I think i have a push fit fitting somewhere, will try it out.
I’ve only ever used standard compression tightened up fully and never had a problem tbh.
The Euro rubber reducer deffo looks a good solution if you’re not a plumber and want to fit with more confidence.
  • 2 weeks later...
Thanks for all the posts. I ended up changing the solvent weld elbow into a compression elbow and then got the rubber seal which fits perfectly for anyone else looking for a solution to this. It just sits inside the regular compression seal.
