DELTA FRAME AND Trim saw. How do you call it.
Patrick
Trying to buy one of these
a0a2e763-b28b-4b23-a797-14b04de70ed7_lar
Americans call them frame and trim saw.
Nothing on ebay or online anywhere in the UK. Closest thing is circular saw with guides/ rail. But thats not what I need. I got a mitre saw, but the ones you can buy/the ones I see online only allow to cut 300mm wide boards maximum. These(from the photo) do up to 600mm, which is exactly what I need. Is there anything similar and if yes, where can I find it/what is it called?
Look out for a RADIAL ARM SAW loads on e bay.
I take it this is to cut your i joists.
Big bit of kit, you will need to make a long table to sit it on and bring every i joist to the saw, it is sometimes easier to take the saw to the timber, just make a jig for multiple cuts and use a  circular saw.
Never heard of those before, I have a tile cutter that’s similar!!! Did find this one but not big enough for you I guess. I also have a triton work centre that allows the saw to slide above the wood but not sure of max width (it’s buried in my container so can’t measure it,
https://www.toolstation.com/triton-twx7-910w-project-saw-127mm/p10002?store=FB&utm_source=googleshopping&utm_medium=feed&utm_campaign=googleshoppingfeed&gclid=CjwKCAjw_LL2BRAkEiwAv2Y3ScUclkwM3_mIg1ec0NL3Cgx9zDSOqmAe9ba_5q_gi-8EBHgdA4oORhoCzUwQAvD_BwE
if Russel is right and you want it for I beams , I have a large radial arm saw but far too much trouble carrying the beans into my workshop, I made a jig/guide for my circular saw to cut them in situ.
Edited by joe90
@joe90
This is very close but just about 50mm to short. Need more than 500mm.
@Russell griffiths
Amazing. Thanks a lot. That s perfect for me. Exactly what I was looking for. You're right with the taking the saw to the I beam part, but this one is not for my house,  it s for work and the radial arm saw exactly does what I need.
This forum is so f...ing usefull. Time after time after time?
 I had an old 10" radial arm saw, a DeWalt 110 I think it was. Very useful saw, but mine was underpowered with only a 1kw motor, so I'd advise getting a newer one with a bigger motor and going to 12* blades.
They seem to sell quite cheaply secondhand, but they are heavy beasts, not portable.
definitely ? But once set up in a “station” with large in and out tables very useful. Great fir “troughing”.
Edited by joe90
DW110 --that brings back memories of the 70,s
I used to make and sell custom speaker cabinets  in exchange +mart using one,
no internet or ebay then
it was that and making kitchen units that funded my first garage .that and selling 8 track car  units  on there -my bedroom at home was full of them -had to but 200 at at time to get price right -
using conti board which was really chipboard wrapped in fablon like material --or  real wood veneer
it was so accurate i could do a 45 angle cut from both sides,not cutting the wood grain plastic facing , then fold the conti board to make a cabinet.
cut rebates inboth ends for the speaker carrier board and back lid
and send as a kit for the DIY hi-fi  nerds to build thier own
biggest ones i did -a special order -were 6ft tall and 3ft wide and 2ft deep -with another cabinet2"smaller  to fit inside -which he was going to fill the gap with sand
never heard the outcome of it
