Patrick Posted May 26, 2020 Posted May 26, 2020 Trying to buy one of these Americans call them frame and trim saw. Nothing on ebay or online anywhere in the UK. Closest thing is circular saw with guides/ rail. But thats not what I need. I got a mitre saw, but the ones you can buy/the ones I see online only allow to cut 300mm wide boards maximum. These(from the photo) do up to 600mm, which is exactly what I need. Is there anything similar and if yes, where can I find it/what is it called?
Russell griffiths Posted May 26, 2020 Posted May 26, 2020 Look out for a RADIAL ARM SAW loads on e bay. I take it this is to cut your i joists. Big bit of kit, you will need to make a long table to sit it on and bring every i joist to the saw, it is sometimes easier to take the saw to the timber, just make a jig for multiple cuts and use a circular saw. 1
joe90 Posted May 26, 2020 Posted May 26, 2020 (edited) Never heard of those before, I have a tile cutter that’s similar!!! Did find this one but not big enough for you I guess. I also have a triton work centre that allows the saw to slide above the wood but not sure of max width (it’s buried in my container so can’t measure it, https://www.toolstation.com/triton-twx7-910w-project-saw-127mm/p10002?store=FB&utm_source=googleshopping&utm_medium=feed&utm_campaign=googleshoppingfeed&gclid=CjwKCAjw_LL2BRAkEiwAv2Y3ScUclkwM3_mIg1ec0NL3Cgx9zDSOqmAe9ba_5q_gi-8EBHgdA4oORhoCzUwQAvD_BwE if Russel is right and you want it for I beams , I have a large radial arm saw but far too much trouble carrying the beans into my workshop, I made a jig/guide for my circular saw to cut them in situ. Edited May 26, 2020 by joe90
Patrick Posted May 26, 2020 Author Posted May 26, 2020 @joe90 This is very close but just about 50mm to short. Need more than 500mm. @Russell griffiths Amazing. Thanks a lot. That s perfect for me. Exactly what I was looking for. You're right with the taking the saw to the I beam part, but this one is not for my house, it s for work and the radial arm saw exactly does what I need. This forum is so f...ing usefull. Time after time after time? 1
Miek Posted May 27, 2020 Posted May 27, 2020 I had an old 10" radial arm saw, a DeWalt 110 I think it was. Very useful saw, but mine was underpowered with only a 1kw motor, so I'd advise getting a newer one with a bigger motor and going to 12* blades. They seem to sell quite cheaply secondhand, but they are heavy beasts, not portable.
joe90 Posted May 27, 2020 Posted May 27, 2020 (edited) 41 minutes ago, Miek said: but they are heavy beasts, not portable. definitely ? But once set up in a “station” with large in and out tables very useful. Great fir “troughing”. Edited May 27, 2020 by joe90
scottishjohn Posted May 27, 2020 Posted May 27, 2020 DW110 --that brings back memories of the 70,s I used to make and sell custom speaker cabinets in exchange +mart using one, no internet or ebay then it was that and making kitchen units that funded my first garage .that and selling 8 track car units on there -my bedroom at home was full of them -had to but 200 at at time to get price right - using conti board which was really chipboard wrapped in fablon like material --or real wood veneer it was so accurate i could do a 45 angle cut from both sides,not cutting the wood grain plastic facing , then fold the conti board to make a cabinet. cut rebates inboth ends for the speaker carrier board and back lid and send as a kit for the DIY hi-fi nerds to build thier own biggest ones i did -a special order -were 6ft tall and 3ft wide and 2ft deep -with another cabinet2"smaller to fit inside -which he was going to fill the gap with sand never heard the outcome of it 1
