so I have a 22mm copper mains feed for my cold water manifold which I want to build / install and want to use HEP2O with a central manifold and a separate pipe for each feed.  If I use 15mm for the bath, kitchen and utility sink and 10mm for washbasins and toilets does this sound right? I would keep a couple of 22mm blanked of for the UFH heating when ready for that.
8 hours ago, PeterW said:
UFH is filled using a loop then disconnected. 15mm off the rising main will do.
thanks peter, so otherwise the pipe sizes look OK to you?
That’s exactly what I did, with 15mm to showers, works great ?
one fir hot and one fir cold.
(Not the neatest instal but pipes went in early)
Edited by joe90
Add
30 minutes ago, pocster said:
I must show a picture of mine - I must !!
15mm for everything
ok, so yours is bigger than mine (and neater) ? but I have to say basins run in 10mm gets hot water very fast (at least mine is finished ?????)
Don’t care ! Mines the biggest
Neater??? Wtf dies yours look like then?
1 hour ago, pocster said:
Ah ! But in theory my 15mm bath should fill quicker ?✊
no, my bath, kitchen sink and showers are all 15mm, basins and toilets in 10mm ?
My toilet cistern will fill quicker ! ?
14 minutes ago, joe90 said:
?‍♂️ (Could not find an iMogi with tongue sticking out j
I've been looking for one of those for ages and all I can find is emojis.
A tongue in cheek one would be good too.
  • Haha 2
23 minutes ago, pocster said:
Probably get taken down ; but I’m bored
so, all your jobs are complete then??
No he's only got the frame in and not the pan yet.
