I have a small shower room in a small outbuilding/office with waste plumbing as in the drawing.
It goes to a sewage treatment plant and this is vented at the end of the run through the roof of a barn conversion about 25m upstream of the shower room/office.
In the interest of the toilet not sucking water out of basin/shower traps is my best option:
1. fit anti syphon traps to both shower and basin
2. fit an AAV - if so where should it go? can it go where I indicate on the drawing or should it be closer to the toilet (upstream of the shower and basin)
3. Fit all the above.
4. Don't bother with any of them - it will all be fine!
I would fit one where you have indicated.
I would extend the pipe up above the WC and fit the AAV there.  There is a risk of sucking the water out of the basin trap when you flush the WC.
  • Like 3
Could I just go for a basin trap with built in AAV as I will have some issues getting an AAV behind the toilet?
I think I hadn't quite clicked that an anti syphon trap is essentially an AAV.
