Hi all,
In order to keep costs down I am thinking about having a main contractor complete the build up to 1st fix and then completing the second fix onwards my myself.
I've no construction experience but I'm okay at DIY, fitted bathroom, kitchen etc.
Any thoughts on how this could play out?
When you say your ok at DIY what exactly do you mean. 2nd fix is all the nice bits that aren't hidden so they need to be right or you will be looking at them forever.
I was thinking the decorating, tiling, flooring, kitchen, bathrooms, fitting internal doors, skirting and window boards, landscaping etc. I assume I am allowed to fit switches, sockets?
When needed I'll get trades in to do the jobs I can't, like heating, plastering etc
We have done a mix of contractor and DIY second fix.  Here's the breakdown.
Stud walls - extra ones needed additional to those supplied by timber frame company: DIY
Sound insulation in stud walls / ceilings: DIY
Plasterboarding: Sub contractor
Plastering: Sub contractor
MVHR fit: DIY
Internal doors / door frames: DIY
Window boards: DIY
Stairs: DIY (got a chippie friend in for some initial advice, thereafter doing it ourselves, including fitting landing glass and finishes - still to do)
Second fix plumbing: Sub contractor
Second fix electrics: sub contractor
Kitchen fit: sub contractor
Tiling: sub contractor (glad we did this particularly as a much better job over a huge floor area)
Painting: DIY
Skirting: DIY
Wood flooring / carpet fitting: sub contractor
Wallpapering: DIY
And its not over yet.......(started in Jan, still not finished inside or out)
So a real mix.  Saved a lot of money.  Worth noting that this has cost us a lot in time but has actually been fun.  Learned a lot along the way too.
And our finishes in some places would not be good enough for some people probably......
3 hours ago, Moonshine said:
obs, you couldn't do second fix electric nor anything gas related in second fix plumbing.
Good idea You will save a chunk of money
I did most of the build including wiring and heating You will need someone to sign off your electrics and boiler
Id a plumber and Electrian friend who checked all the first fix before I plastered the inside
But if your going to get it first fixed It should be a doddle
Just ask who ever does the first fix if the will sign it off at the end
