Well I’ve dremel cleaned my grout lines .
Some of the tile spacing is less than perfect on close inspection . I don’t like the white cross plastic spacers . One of the reasons I make a mess is I try to position them vertically and therefore I use a small amount of adhesive to hold them there ...
Have ordered some different type of spacers that can do corners ( which I want ) I.e 3 way . 2 way and 1 way just by rotating them . I want the bathroom tiling to be better !!
Edited by pocster
Your practice run is better than my finished tiling!
Just now, pocster said:
What did you do to space tiles vertically ?
Just used the little 3mm + shaped things. They held in fine.
I just went wrong by not using a levelling system! ?
But they never stay in . Just pressure from a tile on one side and on another side - fall out ! ?
Edited by pocster
Problems with small things falling out...sound familiar?
4 minutes ago, pocster said:
So !
Coloured grout and Mastik has arrived .
Whats the best tool / Mathis to point the grout ?
Mathis?
Wasn't aware you pointed grout tbh. Ram it in then wipe off with sponge at 45deg so as to never run along a grout line and inadvertently remove the grout.
Edited by Onoff
3 minutes ago, Onoff said:
Mathis?
Method - was what I was trying to type ?
Ok ; so damp sponge across ??
Hmmmmm
This metal beading feels a bit hopeful !
It requires skill is what I mean !
Ok from a distance .
Less than perfect close up . Will use coloured sealant on ‘gaps’
We have just used the Perfect Level Master (tile levelling system) on our large format floor tiles - the clips are available in 1, 2 or 3mm so they space the tile at the same time as levelling it.
I am impressed and certain that the tiles would not be as level as they are if they had not been used.
Sure
i was on about wall tiles
17 minutes ago, pocster said:
Sure
Don't your red/black things level and keep the gap?
These arrived today . The grout gap maybe 2mm using these . What I do like is they can space corners and edges . Assuming they don’t fall out
Those red/black levellers have a skinny spindle - I felt the gap created would be too narrow
5 hours ago, pocster said:
Sure
Perfect level master can be used on walls, but as you have already worked out - you can use a spacer with your levelling system.
This our floor using the 3mm clips and corner spacers
Edited by wozza
This our floor using the 3mm clipsimageproxy.php?img=&key=f5f06bfe2c42e69cimageproxy.php?img=&key=f5f06bfe2c42e69cimageproxy.php?img=&key=f5f06bfe2c42e69c and corner spacers
I might try them !
Having said all that I’m sure I’ve got some rubi tile levelling stuff here . I assumed it’s just for floors as you kick off the plastic next day . Not sure you can use in walls ?
Similar to the system you mention .
Don’t fancy hammering plastic bits off wall tiles ?
Edited by pocster
They snap off easily as you knock them off inline with the grout line.
Yeah ? So even on wall tiles ? . Nothing worse than the snapped plastic isn’t deep enough I.e shows through the grout .
Says the self confessed, dab hand with a Dremel!
