patp Posted August 13, 2019 Posted August 13, 2019 We are planning an underground heat source pump system. Where do people site their boilers. We have heard that they can be noisy. We did away with the integral garage in favour of a large utility room. The utility room is a fair distance from all living areas. There will be a workshop as part of a triple bay garage a short distance from the house. Would the noise be invasive when using the utility room? I am quite noise sensitive. Would there be heat coming from the boiler in the summer? The dog may sleep in there.
PeterW Posted August 13, 2019 Posted August 13, 2019 Do you mean a Ground Source Heat Pump..?? If so, stick it as far from the house as possible as they can be noisy, and you also need access to change the coil fluid every so often.
ProDave Posted August 13, 2019 Posted August 13, 2019 This is where imho air source is better, it puts the noisy bit outside.
BotusBuild Posted August 13, 2019 Posted August 13, 2019 A ground source heat pump is no more noisy than a traditional gas boiler. In fact they are relatively quieter. 40-50dB at 1-2m distance from the unit is not uncommon, so just above a quiet library or just below a dishwasher. Personally, I would happily have one in a utility room if it is indeed separated from the rest of the house by a wall/door. Another common location is plantroom in side the house (same thing/different name) or in an attached garage.
scottishjohn Posted August 13, 2019 Posted August 13, 2019 hard to justify GSHP in uk with us not getting very low continual winter temps ,extra expense etc IMHO
ProDave Posted August 13, 2019 Posted August 13, 2019 6 minutes ago, BotusBuild said: A ground source heat pump is no more noisy than a traditional gas boiler. In fact they are relatively quieter. 40-50dB at 1-2m distance from the unit is not uncommon, so just above a quiet library or just below a dishwasher. Personally, I would happily have one in a utility room if it is indeed separated from the rest of the house by a wall/door. Another common location is plantroom in side the house (same thing/different name) or in an attached garage. I am the person that complains about the noise of the fridge, so I would not want one in the house. I even went to the trouble of changing the UFH circulating pumps for a better make because they were too noisy.
BotusBuild Posted August 13, 2019 Posted August 13, 2019 Dave, Noise level sensitivity is a very personal thing and positioning becomes a critical factor as in your case. I am just sharing some facts on which other reader can base their views - I spent a few years designing and having heat pumps (air and ground source) installed in various domestic situations, and the first set of questions I asked any new owner was about how they viewed fridge/freezer/washing machine/dishwasher noise. If the design/planning/build timing was appropriate, I would recommend a sound insulated plant room for the more sensitive customers.
