Ajn
Ajn's Achievements
Regular Member (4/5)
47
MVHR Unit Suggestions
Ajn replied to Tumble's topic in Mechanical Ventilation with Heat Recovery (MVHR)
MH-z19 for co2 and BMx280 -
You don't ... or my wife doesn't. But I do, it is fun to play, learn new stuff. Need something to do when the football results or strickly come ice skating is on. -
Sorry not been on for a while. Elswhere in the build we used a couple of special tile trays (they look good but) from Topps tiles. These were new stock to them and while ok they did also provide a waterproof paint substance that is intended to be used under these shower tiles when installing on a wooden floor. So while the timber frame was glued to the concrete we put libral coats of this on the timber frame. We also used tile board on the frame.
I designd ours around the smaller version of the Domus HRX. The spec said it would do 150sqm. Always found this a strange number as it should be about volume. That said it works well as our L shape annex is 98sqm. The unit is in the utility area as we don't have a loft. Main pipe work is 125mm dia galve spiral steel for the main runs and 100mm onto the room inlet/extract. All the extract pipe has rubber sealed joints. All joints both inlet and extract are also sealed with rubber tape then ducked tape. Main lounge/kitchen has two ins and outs. two bedrooms and long hall have one in and out. All these provid flow across the room. The on-suite and toilet off the hall only have extract terminals with a 10mm gap under the doors. The unit runs at 75% for boost, about 30% for CO2 purge and about 15% for normal operation. I set the flows from the terminals to give the building regulation requirements. this was at 30%. There is a C02 monitor in the system so I rfuced the fan to 15% and with 2 or even four people the CO2 is stable around 400. I think the purge comes in around 600 which has not happened yet. The kitchen, toilet (shower) and on-suite (shower) each have a umidity and temp sensor. Rh seems to be maintained around 45%. Towels in the bathroom dry quite nicely without any heat. Efficiencies vary from about 93 to 98% dependent on outside temps. 8 and above outside it is around 95-98%. Below 3 outside it drops off quite a lot as would be expected. Now the downside: I can only descibe the so call "Bluebrain" controller as shite. The clock is not maintained after a power cut of any sort. If you miss a short one in the night it can be days before you spot it. Next is the filter timer, that is it, it is just a timer nothing more, no cheking of reduction in air flow. The filters do need to be cleaned every couple of months. A simple task if you can get to the unit. The 100% bypass stated is not in reality in terms of temperature 100% bypass. While thay may say the heat exchanger is 100% pypassed but the unit as a whove it is not. Air still goes in and out of the unit and as for the most it consits of a big block of polystyrine. So on bypass the incomming air always gains a few degrees. Less is gained on boost. Getting around the "bluebrain" problem: Using my own sensors (based on D1 mini micro controller and ESPEasy) sending data to a Raspberry pi with MQTT and node-red I have added a D1 mini in the Domus controller as it fortunately has a number of inputs and outputs that can be switched/monitored. This added D1 also has a temperature sensor in each of the four pipes going to the Domus as well as the CO2 module. The bypass proccess takes much more account of the outside temp and time of year giving nice cooler night time flow unless the underfoor heating comes on and bypass is stopped. So while the original controller is still 100% in the backgroud to meet the "what if anything happens to me" requirement. My controller overlay allows much more control.... and a clock that is always correct. Finally you do need the set the terminals correctly after working out the flows for each room, the standard building regs can be used to do the calcs. Just work out what each room needs, (allowing flow under doors if needed) add them up and set the unit to provide that flow. Then a cheap airflow meter and some cardboard works fine. Once you have the terminals in the ballpark you may need to adjust the overall air flow and go around the terminals a couple of times. Then set to boost and see if your bathroom/tichen extracts are above the minimum. We have eleven terminals and it only took a couple of hours. Remember to record your data ech time so you know how it is looking and a final set with calculations that looks posh with a dated and scribbled signature that the building inspection can look at and put a tick in his box. Just my view... -
We bought a D3000 Black & Decker 3 way ladder back in 1978 ish. Still got it and would not part with it.
One of our many conditions was for an archeaological survey. There had been some medieval finds within 300m of our site. We looked at vaious options but went with the county archeaological services. They also wanted a lot of photos of the building and barn we were converting. They specified the trenches they wanted and where. they modified them to only include parts we were digging. We had to provide the man and digger but he did other stuff at the same time (which they also looked at). One of them got excited about a pit with bones at the bottom under a clay layer. The bones were chicken and they decided the pit was a tree root ball that had been removed prior to the clay being brought in for the walled garden. Cost was about £1700.
Well yes and no. We had problems with the weather side wall. Heavy rain at an angle of 45deg didn't come in it just ran off until it hit the dpc then came in. Not a lot but if we didn't have to have the dpc then it would be no problem. Durisol will not hold water in any form and would work without a dpc. Key tips though. 1. don't let a builder anywhere near it. 2. a battery grinder is good for removing the odd nib as you lay them. 3. Use string that is not bent for your lines
What would you do differently if you could do your PV install fresh?
Ajn replied to Gill's topic in Photovoltaics (PV)
So they are offering 28 panels of 1.7m x 1.1m @405kW each... on the flat roof of a building that is 14m x 4.5m 12 panels on a building that is not built yet Then there was stuff about a 10kW single phase inverter. and a 5kW battery oh and a 5kW inverter for the 12 panels. Would this be a G99 application then? oh no it would be limited to G98. Would you not use the 3 phase then? That would not change anything. Then he said we can give 30% discount. I did say I thought this was solar and not double glazing we were talking about.... Lets see what the next one brings. -
Can somebody explain this planning spiel in layman terms?
Ajn replied to Barryscotland's topic in Planning Permission
We had the same problem even though the plant room attached to annex fed the rest of property that was 10m over a driveway. They said it could not be separate so we ended up knocking down a 200 year old heated garden wall to join the annex to the barn and then they were happy..... idiots. # -
We fell foul of this one. The "professional" fees and insurances would have been six times the price of our first house we bought 1977. The build loan insurance was the worst. One wanted 12k, we paid 4k in the end.
Yes we do from the not so smart meter. I would have liked to see what each of the phases used but it is just one reading. They did the meter last September (on the second visit) so we have values for the winter period if nothing else. We know what the heat pump did from its log so we can extract that from the total. We do seem to be using a lot of electric £12 a day but it is five years since I paid a bill. our annual bills were around £500 for electic at the old house (4 bed detached late 70's) and £1200 for gas. I did have 3.5kw on the roof. The current place is 320sqm for the main bit and 90sqm ish for the annex but all electric. We do have a solar survey man comming on friday to identify our needs and give us a quote. I just hope he is a bit better than the man who phoned to book the appointment. He asked a few basic questions including heating type... "it is electric and uses a GSHP" his next question was why do you need solar if you are getting the electic from the ground...... So we will see what Friday brings... looking foward to it. -
Ok.. while this thread seems more about "how they are going to tax your EV" than the "what would you do differently" of the original question. So we are looking at PV again. Had full FIT on the old house, just paid for it's self and a full year of it was paying for our electic and gas bills ... then we moved... dam.. So this new project is signed off and we are thinking about PV. We have currently one south facing elevation 14m x 2m that is at 36 degrees. Later we will have another 12.5m x 2.8m of elevation split 50/50 south and west that will be available. So around 4.5kw for the first bit and 4 ish for the later bit. We have 3 phase so G98 will do. We have a GSHP. Just need to work out the battery size to cover out use plus a bit of peak time export if we can. Need to work out what we are using and when but the not so smart meter just gives a total per day. I am thinking to size the battery, if we can use 100% of our needs from the battery and top it up with off peak and solar it will be a saving whatever. Then on my 160th birthday we will have 100% free electric. -
That can happen any time.... for reasons you may not expect.... However we have one of the Dunster sheds/garden rooms we used as extra lounge space for the touring caravan during our five year restoration project. ( well for us and not the caravan) We had a couple of advantages at this site. a) The six to eight inches of top soil gives way to a compact sand/gravel subsoil. b) We also had access to various bits of earth moving kit that we had bought as part of our diy renovation project. So we removed all the top soil and replaced it with six inches of road planings/scalpings. We gave it a good go over with the wacker plate and using a home made water level got it to within a couple of mm. Overall this provides excellent drainage. It is a 5x6m shed. The bottom logs were specific and appear to have some sort of treatment which I suspect is skin deep. The build is easy for two or more people but two is a must. We added 50mm of insulation to the roof along with a thin layer of 6mm osb. Then the felt singles as provided in the kit. The door is a bit of messing to set up and the provided hinges are crap. We used 25mm insulation under the floor with T&G as provided over the top. Electrics by myself were done in conduit on the outside all at the one level then through the log/plank to the steel socket box on the inside. Flexi conduit was used on the corners and for the verticals to the 3 way consumer unit on the outside under the eve. Two mistakes were made nine double sockes was not enough and I had to change the vertical conduit from the light switch to a flexi one as the logs settled / shrunk nearly two inches in the first year. Now I would say there is an inch of movement over a year. The incomming feed is by way of a plug in connection similar to those used on caravan sites and boats etc. This means that the power can be removed without doing anythin in the main building and the shed becomes an extension lead. Obviously isolators and trips etc are rated to the supply cable. Part P is not needed for an extension lead. Having poked the bottom logs with a bradawl and sounded them with a 1lb hammer there is no singn of any problem with these logs yet. With a bit of care it should last 20yrs plus. If it does, that would be an all in cost of £342 per year for each of the twenty years. So with perhaps some improvement in the doors they are not bad value and can be put up in a couple of weekends.
Global warming is in fact entirely natural and has already peaked
Ajn replied to ProDave's topic in Boffin's Corner
Are you trying to watch the latest outdoor WI calendar shoot?
