Hecateh last won the day on August 2 2019
Hecateh had the most liked content!
About Hecateh
- Birthday January 28
Personal Information
About Me
Building a split level bungalow in the garden of my bigger one. Reason 1) fund retirement 2) benefit from modern technology in building and insulation 3) future proof - although on this I am taking a step back also as my current bungalow has no stairs
Location
Hoyland, Close to M1 Junction 36
Hecateh's Achievements
Advanced Member (5/5)
609
I have an old corded drill that I currently use but most of what I do is internal and so into plaster board or at most breeze block. There may be occasional brick to go into (Hanging Baskets outside) but it's a modern house-brick - not like the engineering brick my old house is built of Next year I will be doing the garden and wanting to build raised beds with wood I have (old scaffold board, pallets and decking) and possibly sleepers. Much as I would like, in some ways, to have other power tools I don't think I will get much use out of them and my son has a load of things I can occasionally borrow. It won't get lots of use but I do need it to be reliable and reasonably light. @PeterW are these the same https://smile.amazon.co.uk/Bosch-Professional-2608595362-MULTICONSTRUCTION-BIT/dp/B004Z0TPNY/ref=sr_1_12?crid=10Z7SQ093J0YS&keywords=bosch+multi+purpose+drill+bits&qid=1571130768&sprefix=bosch+multi+p%2Caps%2C233&sr=8-12 - they look identical but ... I'm not sure
Is this a good deal? https://www.amazon.co.uk/Bosch-Cordless-Combi-Lithium-Ion-Batteries/dp/B00L3XK06C/ref=gbps_img_s-4_1a55_6e2e06f6?smid=A3P5ROKL5A1OLE&pf_rd_p=88f6b64b-8dd4-4955-9326-9efe67a81a55&pf_rd_s=slot-4&pf_rd_t=701&pf_rd_i=gb_main&pf_rd_m=A3P5ROKL5A1OLE&pf_rd_r=MTTSQV86HM75P9QKNX3W
Another one for a motion movement sensor night light. I had one built in but my ensuite and dressing room are all one room with a dividing wall down about 2/3rds of it. My wonderful electrician put the sensor so it goes on as I go through the dressing area and if i'm longer than 2 minutes in the loo(which is rare but has been know) the light goes off so I have a back up battery one. I wouldn't have bothered with the built in if I had known, a few of the battery ones which are not expensive, would have been plenty. The batteries last about 6 months so no big deal there.
Where would you put one sqm of extra space?
Hecateh replied to Ferdinand's topic in New House & Self Build Design
Without having read this thread I was discussing similar with family last night. Whee I would have my extra metre is on the dining alcove. It currently looks fine - when not in use. In order to use it properly, the seating in lounge has to be moved. Even an extra 3 - 400 mm in depth would have made the difference. -
New member - looking to self build in Yorkshire
Hecateh replied to Fly14's topic in Introduce Yourself
I think I'd be better at telling you who to avoid. Some were worse than others but none were brilliant. Only definite recommendation is DIY kitchens at Pontefract - lots on here have used them too - but it will be a while before you get that far. -
Hi, welcome to the forum. Whereabouts in Yorkshire are you. I'm close to junction 36, and my build is more or less finished apart from drive, garden, skirting boards and doors. -
Visiting DIY Kitchens showroom in Pontefract. Any advice?
Hecateh replied to Dreadnaught's topic in Kitchen Units & Worktops
My admittedly old sat nav told me I was there and the showroom was on the right. It wasn't - it was a bit further along on a road down to the left. My phone map got me there though so I suspect a newer sat nav will be fine. I'm only 20 minutes away so I went about 4 times before I order but a couple were at weekends when they are very busy so it was easier to see someone to go through my plan during the week. It's a great place. I took my sister once and it nearly persuaded her she needed a new kitchen ---- she definitely doesn't but was so enthusiastic about it when she told a friend, in Bristol, that the kitchens were great and it wasn't worth paying 3 times as much for the one her friend was looking at. The friend made the journey from Bristol to visit (adding in a weekend visit somewhere) and was equally impressed. They now have one and love it. -
another vote for DIY kitchens. Units available in 50mm increments so pretty flexible
I had a tension rod which I could take up and down - where to put it when down was the issue. For this reason and because the curtain will slide along more easily I have changed to a curtain wire. Curtains are sheer and very light and gap is 2.7m. I want blinds up for the winter but can't afford them yet and just want this to provide a slight solar gain barrier, probably won't really need it again after today. The gap is filled by a door - opening out and a bifold, also opening out so there is no fouling. AND the curtains will only be operated gently by me. So it to inside the reveal, I don't think command hooks will work - used them in the old house for the shower curtain and was having to refix every couple of weeks with a direct pull - if placed so the tension was sideways they didn't even last that long.
I'm putting some voiles up on a wire in the reveal. Where is it best to fix the wire? To the window itself, the top of the reveal or the side walls?
I haven't been visiting this site much recently and missed this. I got the same information in an email from a couple of days ago FFS what next. I suppose I need to contact them now and find out what happens now.
I got in a mess with bridging. It was at 13% so extortionate but I planned for it and all should have been fine. Then the house took much longer than planned Then my old house didn't sell and still hasn't I am lucky my sister is loaded and loaned me the money to pay it off but as I am not earning anything I would have been totally up the khyber if she wasn't able to help.
mine's the same
Recommendations for Bathrooms for Elderly / Disabled
Hecateh replied to Ferdinand's topic in Bathrooms, Ensuites & Wetrooms
As things become more automated - an 'Alexa' or similar positioned in the bathroom to enable oral 'drop in' check- 42 replies
- disability
- adapted bathroom
(and 2 more)
