Everything posted by garrymartin
I have Tikkurila Anti-Reflex in bathrooms and in my kitchen. Technically, for the same reasons F&B quote it's not specifically recommended for those areas, but I've had zero issues with it.
Not sure about the Tikkurila, but you can definitely get Johnstone's tinted. Our local Johnstone's definitely used to have the F&B codes for mixing.
Following up on Russell's post, I've used Tikkurila Anti-Reflex throughout my home on the ceilings and would never use anything else. Excellent paint. Hides many issues. Not sure Farrow & Ball have premium paint, but they definitely have premium marketing... 😉
That's still the modern way of doing it. It's a 5A socket used almost exclusively for lighting (table, floor, bed-side, etc.) and they're almost always operated from a wall switch. You see them a lot in high-end lighting installations.
Building control drawing with timber frame
garrymartin replied to Bluebaron's topic in New House & Self Build Design
When we asked this question of MBC, they said they didn't, but they did have a partner company they work with that you could contract directly with if you wanted. Or you could use your architect. -
I think we're going to have to agree to disagree on this one @Mattg4321 - even the OSG states "The current demand of a final circuit is determined by adding the current demands of all points of utilisation and equipment in the circuit and, where appropriate, making an allowance for diversity." I'd argue that it isn't appropriate when you have a final circuit (radial) feeding a single appliance such as an induction hob or an oven as there aren't multiple points of utilisation. AFAIK, the Cooking Appliances calculation has been in the guides with the same information since at least 1966, so I'd argue it's long overdue for an update to take into account modern cooking appliances and installation approaches! 🙂
Diversity only applies where there are multiple loads on a single cable. Whilst it might be appropriate for my combination oven and warming drawer example, it's not appropriate for the induction hob, as this is the only load on the radial circuit. Same reasons as for an electric shower - diversity isn't applied because it's the only load on the circuit.
There's a whole series of tables and calculations related to cable and protective device sizing in BS 7671. Start with this video to understand how complex it can get and why your electrician should be doing the relevant calculations. By the way, 100% agree with the comment about personal research so that you are informed and can pose sensible questions and query statements. But you really want the electrician to be professionally responsible for the calculations and installation.
If you've got an electrician, why aren't they doing the necessary calculations? You have to consider voltage drop over the distances you mention, as well as the route the cable will take and whether any of that route is insulated. Some induction hobs are in the 11kW range. If your oven uses pyrolytic cleaning, and it's a double oven, even 6mm2 may not be enough. At the extreme, an 11kW induction hob at the end of a 25m run of cable enclosed in insulation could need a 25mm2 cable and a 50A RCBO or equivalent. Can't stress strongly enough that your electrician should be looking at these sorts of considerations and advising you on the appropriate cable sizes. Like @Russell griffiths we have 10mm2 to an induction hob, 6mm2 to a pyrolytic single oven, and 6mm2 to a combination pyrolytic oven/microwave which also serves a warming drawer, all on radial circuits with their own RCBOs.
Perfectly fine. Crossing has fewer issues than running in parallel, and even that is not a big deal given the number of cables and voltages we are talking about in residential construction.
You can definitely do it alone @Andeh assuming you have the skills, but you will also need a helper at various points for help with lifting, holding, etc. I built a 3.6m x 4.8m (external, excluding cladding) garden room with a garden store in 2018 with help from my wife. We kept the internal floor area under 15m2 as we were building close to the boundary, and the eaves height below 2.5m for the same reason. Hence no planning permission or building regulations requirement. It cost just over £12K at that time, but that included absolutely everything, including the 3m bifolds, all internal finishing and various sundry tools I bought to make it easier to build. It didn't include the cost of the insulated concrete base and the dwarf wall, as those costs were included in the garden design and landscaping bill.
The biggest IKEA Hemmes bathroom cabinet I can find still weighs less than 40KG. Even when loaded up, there are plenty of fixings that will work without you having to cut out plasterboard. As @Russell griffiths suggests, toggle fixings would work, but I prefer to use GripIt Plasterboard Fixings. They're available at places like Toolstation or Amazon, and come in varying sizes depending on the load you're fixing. The 25mm versions can handle 113KG - see https://www.gripitfixings.co.uk/
Recessing elec conduit in floor for floor plugs?
garrymartin replied to Great_scot_selfbuild's topic in General Flooring
I believe the Part M document refers to "wall-mounted sockets" in relation to the minimum distances. AFAIK, floor-mounted sockets are still allowed, but always best to check with your BCO for their guidance. -
Cat6 cable 305m Where should I buy from?
garrymartin replied to jimseng's topic in Building Materials
It is. And if you have multiple different cabling uses (network, cctv, TV distribution, etc.) it comes in a wide variety of colours. It seems to be a favourite of many high-end installers. -
Listed Building and Double Glazing
garrymartin replied to DavidO's topic in General Structural Issues
I don't have detailed comparisons, but my understanding is that depending on various factors, it can be 50% to 200% or more expensive than standard double glazing. If you're really restricted from a listed building approval perspective, that may be something that's financially palatable though. -
Oh, also, something else I learned on Buildhub from @Dan1983 is Astragal bars which are decorative, surface-mounted strips applied to both the inside and outside of double or triple-glazed window panes to create the authentic, subdivided appearance of traditional small-paned Georgian windows. They might be useful for your situation, given your original images. -
Take a look at https://historicengland.org.uk/images-books/publications/adapting-historic-buildings-energy-carbon-efficiency-advice-note-18/ released in February 2026. I also recently learned about vacuum double glazing when I was looking at similar issues on listed buildings. Might be of interest if you can't get approval for standard double glazing. https://www.vacuumglazing.co.uk/landvac-enhance-heritage-vacuum-glazing/ -
CAT6 will do 10Gbps so long as the cable isn't very long (37-55m max generally). You can't go wrong with TruHD Cat 6 HDBaseT Cable - tested to 500MHz, so good for 10Gbps if needed. Details and pricing - https://www.fscables.com/products/cat-6-hdbaset.html Datasheet - https://www.fscables.com/sites/admin/plugins/elfinder/files/fscables/Datasheets/C6T00-E00.pdf -
Electricity tariffs
garrymartin replied to Russell griffiths's topic in General Self Build & DIY Discussion
I'm not a user, but https://www.sunsave.energy/solar-panels-advice/exporting-to-the-grid/best-heat-pump-tariffs -
Week 40 - We’ve moved in!
garrymartin commented on Benpointer's blog entry in Contemporary build in north Dorset
Congratulations! It's been a privilege to follow along with you as the build progressed, and I'm sure you've given many people hope and inspiration for their own endeavours. May you have many happy years in your new home.- 21 comments
- moving in
- airtightness
(and 3 more)
Week 15 - UFH, screed, and render base coat
Errrr.... that was your photo they referenced @Benpointer 🤣 -
Benpointer on buildhub - "The ‘spaghetti’ in the bottom left corner is where all of our external service ducts come into the plant room. 17 ducts in total, including two spare at present, (I may have over-catered): 1. Power to ASHP 2. Power to garden 3. Water pipe to garden 4. Water pipe to workshop 5. Power to workshop 6. Lighting circuit - switched external lights 7. Data to workshop 8. Live power supply in (SSE - single phase) 9. Fibre in (Openreach) 10. Water mains in (Wessex Water) 11. Power to sewage treatment plant 12. PV panel in 13. PV panel in 14. Power to EV charger 15. Data for CCTV 16. Spare 50mm duct (to workshop) 17. Spare 50mm duct (to workshop)" You might also consider control cables for the ASHP ( @Russell griffiths suggestion) and data to the EV charger if not included in the power cable make-up. -
Week 38 - Nearly there!
Your continued progress and quality of work is quite inspirational. Good luck with moving in!- 4 comments
- landscaping
- tarmac
- (and 5 more)
Securing backboxes - Plastered and proving challenging
garrymartin replied to boxrick's topic in Electrics - Other
I've got another couple of choices in my notes... # Selectric FRB-4 2 Gang 47mm Galvanised Steel Back Box – Earths – Fire Rated **SKU** FRB-4 https://www.electricalsonline.co.uk/products/selectric-frb-4-2-gang-47mm-galvanised-steel-back-box-earths-fire-rated?variant=45425845403874&country=GB¤cy=GBP # Niglon FR472 2 Gang 47mm Dry Lining Fire Rated Metal Back Box SKU: FR472 https://www.electrical4less.co.uk/product/niglon-fr472-2-gang-47mm-dry-lining-fire-rated-metal-back-box/
