MikeGrahamT21
    2
Everything posted by MikeGrahamT21
  1. Yeah I agree, black mould in the MVHR isn't what i was expecting to read there! Does the area where its collected have any interface with air movement at all? I suppose if air never gets near, its probably reasonbly safe, but if it does, there could be spores everywhere. To get rid of the lot, you'd need a 0.1micron filter post MVHR to remove the majority of these, perhaps that is the case? I had considered an MVHR, and still am, but this makes me a little wary. My wife is currently in hospital with a fungal infection in her lungs, so this kind of thing should be taken with a lot of thought, and not just brushed off.
  2. Never knew that, a very useful thing indeed!
  3. One thing I've never found out, is Ozone good or Bad? You hear both sides on the net
  4. Yeah i've got a spare one something like that laying around somewhere, it did remove the smells, but it choked the hood so much, that it barely moved any air, so I took it off, think our hood is just massively underpowered.
  5. That would be brilliant, look forward to seeing what you come up with :-) Yeah a lot advertise that they take out PM2.5 in some way or other.
  6. Thank you for all of the replies, very useful links too. The CarboAir ones seem to be pretty high flow, but I suppose i'd have to match it correctly with whatever MVHR unit I end up with. I suppose the most important question, would it get rid of the smoke smell, and would an F7 (can you get F7 filters?) filter remove the harmful particles? Just trying to keep the dream of MVHR alive, what with all the neighbours who seem to love burning things round here all the time!
  7. Yeah I did think about cannabis myself when I read that lol!
  8. Hi, Everywhere I ask about MVHR and outdoor smoke, everyone seems to recommend a carbon air pre-filter to remove the smell and any organic particles. They are stupidly expensive! I have come across these though: http://www.carboair.co.uk/carboair-100-200-660 Seem to go for anything between 100 and 300 on ebay, which is much more palatable. Not sure they are designed for this purpose, but as long as the air intake can be located inside our ventilated roof space, I don't see an issue bolting this onto an MVHR duct. What do you think? Would it work? And would having the air intake inside ventilated roof space be suitable? Having the intake inside would increase summer temperatures though, so that maybe needs a bit of thinking about. I suppose I could house this in a sealed container, which also has a duct to the outside world.
  9. You can use any thickness of the marmox, dependant on how much insulation/VCL effect you want from the product, obviously the thicker it is the better, but all thicknesses are suitable for tile finish. You don't need any tanking with Marmox, its ready to use once fixed, and is far less vapour open than the other products mentioned, which do let water vapour through despite being waterproof.
  10. You will never get a grab in an AAC block with those type fixings, they only work when theres aggregate present, of which there is none/very little in AAC, always has to be some form of plastic sleeve around the fixing for it to work right. For battens, you need helical fixings, they are quite expensive though, but I found them to have the highest strength of anything out there for AAC. Search Thor Helical.
  11. +1 for nylon plug and coach bolts, they work very well. Just drill your hole slightly smaller (0.5mm) than the plug suggests to get a tight fit. As part of fitting the external wall insulation to our aircrete, I tested about 20 different fixings for various applications in the blocks, and was impressed by the strength of fixing of some of them, so much so that my pull out test involved standing on the block and pull as hard as I physically could, and still couldn't shift the damned thing! But as Nick says, use a plug which is too small for the screw/bolt, and this helps greatly. I used coach bolts and nylon plugs for wall starters off of aircrete, and the drill clicked off with the setting on 25 (almost as high as it will go), so its a very good strong fix.
  12. My vote is for Marmox boards, they also provide a little insulation, but work very well as tile backerboards for both floors and walls, and are impervious to water and also have a high resistance to water vapour permeability. They come in a variety of thicknesses, and there are other brands too, but basically, its XPS inner, with a cement polymer and fibreglass coating on either side. The cement backer boards, such as no more ply are horrible things, really heavy, hard to cut too (you'll go through plenty of blades for both circ saw and jigsaw).
  13. Wow, you must have one large property!
  14. If you don't want to put more plasterboard up, why not just put a piece of wood (or similar) on the lower part, just before the step, and simply paint it. This is obviously only OK if you don't mind the step being visible, if you want it seamless, you will have to overboard... or take the entire ceiling down in the old bit.
  15. I used flexible brick slips (available via ewistore.co.uk), made by elastolith. These are DIY, and very easy to do yourself, just a little time consuming, but they look great when done. We even managed to get a good match. Building on left hand side is existing house, centre is the brick slipped one, and right hand side is a utility with real brick. You could also consider brick effect render, which is pretty impressive these days. There is a growing number of contractors doing this, but expect to pay in the region of £50-£90 per m2, its not cheap. We had a rough quote from this firm: https://www.decopierre.co.uk/ They can do pretty much anything!
  16. I ended up with a continuous extract fan (dMEV) venting out via a roof tile, not what i was after, but it does the job, and it only cost me £30!
  17. Yeah, this is a grit sanding board, very coarse indeed. I bought it to sand down the joints of the aircrete blocks as we used thin joint method, so its probably about the same as you say. To be fair its done a good job, i'd say we have around 30% exposed now, and any bits I've missed i'll pay close attention to individually. Hard to see how much i've done because the bloody adhesive for the thin joint is white and the paint is cream! lol
  18. I got talking to someone who's mother had one put in, they always did all the readings, and submitted them etc, and they kept a record. He noticed when the smart meter went in, the readings started rising, as did the bills, yet the usage remained the same. He rung the company up, and apparently they dialled in and applied a patch to the unit!!!! I wonder how many more are unpatched!!. Its just unbelievable! I shall be sticking with my old clunky, but accurate, wheel meter!
  19. yeah, roughing it up is fairly easy, so im going to do that, just done about 1/3 of wall in 10mins so its worth the effort, plus good exercise! lol
  20. Just been and had a look how well bonded the paint is, stuck some airtight tape to the wall and pulled it off, and some of the paint did come off, not sure if that is OK or not. I could rough the surface up with a very coarse sanding board I've got, which should provide enough key, or just put a test spot of adhesive on, and see how easy it is to get off. Ideas?
  21. I think i may have found a better solution, which I have actually used before as a tile backer board... Marmox Multiboard (in fact i've still got some of it left!). They're not stupidly expensive, and I'll save me on a few bags of expensive plaster, which can be replaced with cheaper board finish. I never realised you could use it in place of plasterboard, but more importantly it has the insulation layer, which is closed cell, with an Sd value of 3m, perfect for what I want! Thinnest they do now is 4mm (i've emailed Marmox for recommendation), which is suitable for dry lining, and its also ready out the box for a plaster skim according to their website. and I'll use some BAL white star tile adhesive to fix to the painted blocks (unless someone can recommend a better tile adhesive for the situation?).
  22. If you want it to look perfect at the new wall thickness, i would imagine you would need new door casings which are wider, a fair bit of money involved and time and effort, but it will then look perfect.
  23. Have a read of the link i posted. If you cut it down, the roots grow even quicker, the stump is the access route for herbicide, so don't cut it straight out, make good use of it! Any form of cutting, and it will simply strengthen whats left. So the last thing to do is cut it down, when it is truly dead.
  24. Link for the article regarding Triclopyr: http://homeguides.sfgate.com/chemical-kill-ficus-roots-62378.html
  25. Whatever you do, plan your attack and go in with intent!
