Kev106
Personal Information
  • Location
    Derry, NI
Kev106's Achievements
Member
Member (3/5)
4
  1. I would avoid Quinn's, anything else should be fine.
  2. Not many brickies will lay 300 block a day on a timber frame.
  3. They make them here in Derry 140 x 140 x 440 concrete. Bit far for you though
  4. Just a heads up guys, here is a supplier of insulated slabs similar to Creagh's Spantherm http://www.nu-span.com/index.html I've no affiliation, just came across them through work.
  5. It may be different now but that's what I paid a year ago. Most of the other prices I got were 65p +.
  6. Clady Timber, Portglenone or Mackles building supplies Toome.
  7. I paid 46p + vat for a 350mm stainless steel wall tie last July. I would imagine they're still about the same.
  8. It's something similar to the link below. I have an oil boiler located in my detached garage. This prevents me from heating my back yard http://www.treco.co.uk/products/boiler/Uponor-Pre-Insulated-Underground-Pipe
  9. We put our knobs a bit lower than usual to give more clearance
  10. I got 9 metres of 6" single wall flexible flue liner for £120 + vat. Shouldn't cost u anymore than that.
  11. If you contact Keystone direct they will custom make whatever you need.
  12. These are the guys I used. M Henry & Son's 07962309667. Should be a fella Joe you'll be talking to. They done a small flat roof over my bay window.
  13. Maybe a bit late for you now but may help someone else http://m.schoeck.co.uk/en_gb/solutions-uk/cantilever-structural-components-7
  14. It's good to be back! I can put you in touch with the guys that installed my in roof system if you'd like?
