Everything posted by Adsibob
Was this for a flat roof or a pitched roof?
It's very far from a passive house. We are: taking a 1930s semi that has had zero work done to it since 1930, apart from some first generation uPVC double glazing installed (which converted the first floor rear bedrooms into saunas during last summer - which was itself a pretty hot summer for English standards!); completely gutting it extending the rear with a full width ground floor extension and a partial width first floor extension as well as converting the loft; replacing all the glazing as well as introducing 5 sky lights; and upgrading the insulation of the house with a new concrete or limecrete slab and 100mm of insultation in the floor, and then all old walls of the house (that are not being knocked down to make way for the extensions) are being upgraded with 52.5mm of Cellotex insulated plasterboard on the inside and 25mm of this insulating lime based render obviously all of the ground floor rear wall and the extended portion of the first floor rear wall will be a cavity wall to current building regs. All other walls in the house are NOT cavity walls. Appreciate that one can always put in thicker amounts of insulation, but we don't have the space for it. In terms of solar gain, my main concerns are: the rooflight in the flat roof of the first floor rear extension which will be the roof over part of our master bedroom - the architect has specified as 2000mm wide by 1000mm deep, to match the 2000mm width of the window this sits by. I think this is too big, so will probably keep the 2000mm width for aesthetic reasons but reduce the other dimension to 750mm or 600mm the aluminium 2G sliding doors we will install in the new ground floor rear extension which will look out onto our west facing garden. These are pretty big, aproximately 3.7m wide by 2.15m high, which together with a large window that is also on that elevation (also 2G) mean the west facing wall of that ground floor extension is almost 65% glass. the rooflights and veluxes in the loft which are west facing (i'm not too worried about solar gain from the east facing ones, as I think that will help warm up the space in winter more than it will bother us in summer). On the sliding doors for instance, I asked the supplier about adding solar control glass to reduce the G value and the only options available are tinted. Is that always the case? As you will see from the attached picture, the tints look pretty dramatic! Doc1.pdf
Thanks @PeterWAccording to this only the paid for SketchUp studio does "thermal comfort analysis" and "daylight analysis". Or have you found an equivalent feature in their free version?
No, he hasn't. I asked him to and he said that normally one would get a specialist consultant to do this because mapping out the seasonally changing arc of the sun vis-a-vis the obstacles that cast shade on the house is quite technical and would require some modelling. Not sure if he is overcomplicating things or not. Can anyone refer me to some (hopefully free) online calculators that can take inputs such as room size, window size, glass spec, window orientation, latitude coordinate of property etc. so that I can try and work this out for myself?
True, but only a theoretical risk in my opinion. As long as there are plenty of wealthy countries run surpluses (e.g. South Korea, the Netherlands, Switzerland, Singapore) there will always be demand for cheap debt. Even after the rating agencies downgraded the UK's sovereign debt rating from the top quality rating to the next rung down (I can't remember when, it was two or three years ago due to brexit and the fall in the pound) it was still incredibly cheap to borrow.
Best spec for high pressure hot water to multiple outlets?
Adsibob replied to sendu's topic in Boilers & Hot Water Tanks
@Nickfromwales thanks for that. Are you suggesting that if I use a Grundfos Comfort pump on the secondary loop and 10mm pipes for the secondary loop (and just use this secondary loop for basins), I won't need to install a timer? Will 10mm be enough for the supply to a kitchen sink given that will need more water than a hand basin (it's a large sink)? -
@Onoff I did indeed find that useful. In particular this product https://www.lime.org.uk/products/sublimer-insulated-limecrete-floor.html looks like it might be much better than the concrete slab I had envisioned. I'll keep researching and update you all once a RICS surveyor (hopefully one trained by Pete at Heritage House) has had a look.
Not had the chance to look at the first link, but https://www.lime.org.uk/products/sublimer-insulated-limecrete-floor.html looks like it might be much better than the concrete slab I had envisioned. Thanks @Roger440! I'll keep researching and update you all once a RICS surveyor (hopefully one trained by Pete at Heritage House) has had a look.
Thanks @PeterW. I’ve just emailed my photo to heritage house and asked if they could attend to do an urgent survey. They have an office in London, so fingers crossed they can.
I can’t see how to buy it; the website you linked doesn’tappear to sell it - or maybe it dos and I’m blind - and it’s not on amazon.
Thanks. This appears to be the updated version of that book, albeit only written by the co-author to the original: https://www.amazon.co.uk/How-Investigate-Damp-Practical-Inspection/dp/0367434954/ref=mp_s_a_1_1?dchild=1&keywords=ralph+burkinshaw&qid=1610924359&sprefix=ralph+bur&sr=8-1
How can one be sure about this?
You may be right. I simply don’t know. But I need to get a trustworthy surveyor to have a look. I have a RICS surveyor in mind who inspected a damp issue for me many years ago and fixed it without recommending injections, so hopefully he will give an informed view.
Thanks @PeterW, but was just wondering about this... if I just run the secondary loop for the kitchen tap and the three other basins in the house, that’s going to be about 35m to 40m in secondary loop. Using a 10mm pipe for that would hold about 0.1l per m (I’m assuming!), so say 4l in total. How does that compare to the volume of water in the secondary loop in the commercial building you mention? -
The issue is that we need to drop the finished floor level by 420mm in that room. So we are getting the FFL closer to the damp.
If you are 100% sure of what you want to do, I agree an architect might not be necessary and that an engineer is going to give you more value for money, but I wouldn't skimp on the measured survey. Having really accurate drawings done with precision measuring equipment such as those made by Leica pay for themselves in the end, because otherwise small inaccuracies can lead to multiple revisions of subsequent plans. Having said that, we thought we knew what we wanted, but we consulted a pretty famous architect for an initial ideas package and found his input invaluable. He got us to think exactly about how we used our home, what we liked about it and what we didn't, all the annoyances, warts and all, and he found a solution for everything and came up with an idea we hadn't thought of which involved moving our staircase from the corner of the house to the centre and putting in a big rooflight above it to bring lots of light into the house. It's a bit crazy to spend so much on a new staircase because there was nothing too wrong with our original one, but it did waste a lot of space and this new layout is going to completely revolutionise the space. We couldn't afford to do the whole project with this superstar architect, so after paying him £1k plus VAT for his ideas package, we then commissioned a much younger architect to implement these ideas into an actual workable scheme. He made a few mistakes along the way, but we got there in the end and saved a lot of money.
No, but I did get a quote for it. Very expensive, and not worth it in my opinion. When you say sound transmission, do you mean impact sound or airborne. For impact sound, cheaper options which will work similarly well to the TorFloor RdB, though is more labour, is to lay your structural floor chipboard or ply directly onto the joists, then 6mm rubber matting from a company such as SoundStop.co.uk, then a slim underfloor heating system such as LoPro which is only 15mm thick. If you used something like plywood for your structural floor you could go as thin as 18mm making the whole thickness of your floor 39mm before you add your finished floor material, which can affix directly onto the LoPro. For airborne sound you can fill the void between the joists with failry dense mineral wool, that will help with sound insulation. More costly sound insulation that can be substituted for the 6mm rubber matting is something like Cellecta Screedboard 28 but this is heavy and expensive. It comes in thinner thicknesses as well, check their site. That is mainly for impact sound, but i laid it in a ground floor flat, together with flanking strips, and it muffled airborne sound coming up from the basement flat below us, so it will help a bit with airborne sound.
You can have a maximum of 25 Tado devices in your home, which unless you live in Buckingham Palace should be plenty. There is also a limit of the number of devices per room, but again that is generous, something like 7. More details here: https://support.tado.com/en/articles/3752302-how-many-devices-can-i-add-to-a-room-in-the-tado-app All devices talk to the app on your phone (also accessible on a web browser should you lose your phone). The way it works is you get a bridge which you plug into your wifi router and then all the devices talk to that, therefore only one of the devices needs to 'connected' to the boiler. If the heating is on more than one zone, then unless you have a boiler, such as most of the current Veissman range which can connect to the bridge wirelessly without needing anything plugged in to the boiler, you need to buy a separate dongle called an extension kit and that is plugged into the boiler. If everything is just on one zone, you can hardwire a tado thermostat (very easy to do as the connections are just like a traditional thermostat) to the boiler, and then create pseudo zones on the radiators by using smart tado TRVs on each radiator. As for your question on the interface with the manifold, I think this article answers your question: https://support.tado.com/en/articles/3482224-how-does-tado-control-underfloor-heating-systems but if it doesn't, definitely worth contacting Tado support who are always very proficient and responsive. If you have a UFH system where each zone has a thermostat, you simply replace each thermostat with a tado thermostat and buy the wifi dongle to speak to them and an extension kit so the app can also chat with the boiler. -
Following some excellent tips and pointers from @PeterW, @AliG and others on this site, I'm starting to think that I need to reconsider the location of my unvented indirect hot water tank. My question is: in an ideal world, if you have a three storey house, with the boiler on the bottom storey, the two main bathrooms on the middle storey and an extra bathroom that will only get used at weekends on the top storey, on which storey should the unvented indirect hot water tank be sited, or does it not matter? Does gravity have an impact? I guessed gravity wouldn't matter when hot water is going from the boiler to the cylinder, but that gravity would help when water is going from the cylinder to the rest of the house and on that basis, and the fact I wanted to be efficient with use of space, I planned on having the cylinder in the loft. But that is just my guesswork, as my builder is yet to introduce me to his truant heating engineer. Should the cylinder actually be nearer the boiler to reduce heat loss along the journey between the two, or can that just be mitigated with pipe insulation? The boiler could probably go in the loft as well - it doesn't have to go in the ground floor.
What’s a buffer tank? Is that the same as an expansion vessel? I’minstalli g a low loss header as well, as I thought that would make the boiler more efficient. Tado is just a smart thermostat that can be controlled from anywhere in the world and that can use geofencing so that your standard routine is switched off when you leave your house, meaning you never forget to switch the heating on. It then switches back to “home mode” when you return to within x distance of your house - you can set x. so each zone will need its own thermostat. So I will need 9 tados. Expensive, but amazon do good deals on them whenever there is an amazon prime day or Black Friday sale. I will put my existing Tado TRV valves from my old radiator setup onto the towel rads in each bathroom, and then I can add those to the routine. It’s really a wonderful setup. When we installed them in our old house we saved a third on our heating bill. Also really good during winter if you unexpectedly return home, as you can switch your heating in on during the journey home. -
Yeah, I see where you are coming from, but I’m pretty fed up of Vaillants - I’ve had problems with two of their combi boilers. I like the Tado thermostats, and they talk directly to Veissmans without needing extra kit. Veissman also rated highly by which magazine. Apart from towel heater rads in the bathrooms, we are planning to have about 9 zones of UFH throughout the ground and first stories and then haven’t decided about the loft. It was going to be rads there, but might get away with no heating in the loft, or just some undersized rads. Why do you ask? -
I’m in a very similar situation to @DeanAlan. Except mine is possibly worse, as when we did our trial holes earlier this week to expose the foundations we discovered the water table was about 1m below our finished floor level! (See photo.) It’s been raining in London quite a bit these last couple of weeks, but not crazy amounts. I suppose it’s a result of deforestation and climate change. Water has seeped up the bricks and, yes as the 1930s semi is now 90 years old, there is a lot of damp. I too need to drop my FFL to accommodate a new extension (in my case by about 40cm) and I’m replacing the timber subfloor with a concrete slab. My structural engineer and architect are working on a solution, which I will post here before deciding, but they did say they would include injecting a chemical DPM so curious to hear from people such as @PeterW as to why they think injecting chemicals is a bad idea / scam by the damp treatment industry.
That's an interesting idea @AliG. Is that one mixing valve per outlet, or just one for the whole system? Why doesn't everybody do this and fit a smaller tank? there must be a downside, like increased running costs.
