BartW
Everything posted by BartW
Zehnder Q350 + ComfoPost CW12
BartW replied to BartW's topic in Mechanical Ventilation with Heat Recovery (MVHR)
Hi, I used some basic calculators online like heat punk and rounded up. UFH is fairly straightforward. You just lay pipes at 100 - 150 - 200 increments, and it is almost guaranteed to work. I know it sounds very ignorant, but it is that easy, knowing that you will never run the UFh at its full potential (if fraction of it). ASHP is sized up, and I used 7kW AroThermPlus with the sleek looking all in one UniTower. Forget Comfo post. -
Beam and Block floor and ventilated void vs Timber Frame
BartW replied to BartW's topic in Foundations
So I extended the vertical sleeves up and cut them into the charred timber cladding, then bought metal decorative grilles that have got a fine mesh and pretty much do not obstruct airflow vs designed air brick flow. Patio level is up as well, so it looks really clean. -
Hi, Thanks All for replies. Sorry, I took some time to get back to this. I investigated and water gets under GRP and facade treatment, and my suspicion is it drips into the balcony screen U frame then somehow through bolts fixings and gets inside. I sketched it below:
Hi, I am after some advice... We have windows and sliding doors in the timber frame, and a couple of them are leaking. One is in fact allowing water to pour into the property. We have them installed on installation foam, then sealed with silicone on the inside joint, and butted against with plasterboards. There is timber cladding externally, and upon discovery of the leak, I stripped timber and added silicone externally, but that has not helped. I am now at the point where I need to miracle something out before we move in four weeks time. How do others do in in a timber frame construction? Many thanks! Bart
Yes exactly my point and yes I read the exact same page. And it does mention circulation pump, but which one. as for the buffer, yes we have three floors of UFH. I just still don’t know if there is a pump in the tower already…
Hi all, a bit of a call for help. I have finally started the installation of vIllant unitower plus with Heat Pump. Many months ago when discussing this in relation to primary / secondary pumps and ways to connect the buffer it was said no need to have an additional pump as the one in the heat pump will pump the water in the circuit, and then individual manifold pumps will do the rest. well… when following the installation guide today, I cam across “connect the pump”. Wait a minute. I have not got one, I thought it was built into the unitower right? I am assuming that whatever pump the external unit comes with is part of a completely separate sealed circuit. So do I actually need another pump to push the water out of unitower and around the heating pipes? Many thanks! bart
Hi, Quick question: I am wiring multiple RGBW Tree dimmers and using them as separate "individual" dimmers. So 4 channels per device. The way they are wired is common positive, and separate negatives. Can I common up all positives from, say, 3 separate dimmer devices into one 8x4 terminal block, and then just run separate negatives to all individual channels?
Thanks, my only issue is that if I don’t do it now, I will never get around to changing them. Flex switches are cool, but turn out to be pricey when you consider pattern runs and their cost to set up the print. the Alibaba equivalents seem attractive option and fairly straightforward whilst giving dry contacts and looking “okay”. Then there is a mini computer option gia rs485 but as you said, will ever use that…
thank you! that’s one sensible answer that has been seriously considered. would they look odd if I mixed them in the same room? does faradite pose a slightly better value for money option than standard pure? And how usefule are the temp / humidity / co2 sensors in bedrooms? I was hoping to have one co2 switch per room to help trigger mvhr. Or should I not bother?
I bet they look pretty when are set to operate 2 blinds, and 4 light circuits all off one single switch plate?
What about something like this: https://www.alibaba.com/product-detail/90MM-size-12-24V-DC-dry_1600322834351.html?spm=a2700.galleryofferlist.normal_offer.d_image.3be1382bHSdj09 A lot of dry contacts and ability to specify what particular buttons might / should refer to, which could be interesting and make for an easy all in one solution. Or even this for RS485 interface: https://www.alibaba.com/product-detail/Custom-4-Inch-Smart-Hotel-Multi_1600589507298.html?spm=a2700.details.0.0.30d5754ev1Pdnt Anyone tried something like these?
Does nobody use the expensive Loxone Pure CO2 then? Or even ones without CO2?
Hi, I am still debating which switch to choose. my thoughts: - Loxone Pure CO2 in bedrooms and Standard Pure in all other locations. Downside is that I would end up spending around £5k on switches alone - Loxone Pure. Forget CO2. Still nearly £5k… - Pure Co2 in key areas, but everything else would be standard tree switch in black. All in for less than £3k, but aren’t they ugly… - as above but replace Tree switches with retractive where feasible. Just over £2k for switches, but a complete mix of different solutions - Faradite - good looking, still £3k for switches with nanos, but missing a black glossy finish any opinions please? thanks bart
Good idea. i might know a person or two, but otherwise ignore would be my choice. Unless they insist to see it as part of the sign-off.
yes, and yes I will no doubt need someone to sign it off.
runs on 28mm diameter which is full bore. I think I will triple check .
I would find the valve a lot cleaner solution (and quicker, and I have already bought it...)
How do you then fill it?
I am using Unitower and that has an expansion vessel on the intake of cold water to the system. I think there is also a built-in expansion vessel for the central heating circuit. The pressure reducer is for the water inlet, and looks like the below (and I could not work out why so many outlets):
Hi all, as titled. installing AeroTherm Plus. daft question but what order and where do I install the: - antifreeze valves. Outside last point before the heat pump ? - y strainer just behind antifreeze in flow? - flush fill valve in flow presumably inside? - flow and return stopcocks presumably inside? i tried researching but there is no diagram anywhere. Clearly, if you know you know… pic for reference: also on the pressure reducer do I just blank two tappings out of 5?
Which you have by default in loxone.
What benefit is there in using 1 wire sensors over the standard resistance probe?
Standard UFH sensor probes from UFH suppliers are resistance based, so assuming they should be ok to wire to the analog input on the cabinet?
I went for it on my house. Ended up overordering by about 25%. I gave some cuts to people I knew, and it kind of caught on in the way that I started selling it. Lovely stuff! But as @Thorfun said, it is so fragile that just by looking at it you are risking damaging it. But if I were to do it again... I defo wooooood
And I tried. Nothing to do with them. Next stop: Cherwell Council Planning Office.
