Silage
Personal Information
Location
Kent
Silage's Achievements
Member (3/5)
1
I know this is an old topic but i'm guessing that unless the windows are fitted flush with the outer frame (or overhung) then water ingress protection of the outer window reveal is needed, hence the DPC in @oranjeboom 's original drawing. This maybe more of an issue with a timber clad option due the reduced depth compared with brick or stone. What did you go with @jack?
@PeterW Great drawing. WHat's the tank adjacent to the UFH manifold. At first I though it was a buffer for UFH and maybe a take of for rads but it has a coil and the UFH is a direct feed to the UFH?
- 23 replies
Any particular spec for the Rockwool? I've got 304mm posi joist so that woullkd be a lot of Rockwool, and it may be beneficial to get some heat transfer to the 1st floor?
Creating a fall on a flat roof: and attaching the wall plate for it
Silage replied to ToughButterCup's topic in Flat Roofs
@jack great reply thanks. -
Ca I ask does anyone have detailing of drainage for a parapet roof. It was mentioned above that a drainage 'gutter' be formed in the insulationto fal to the outlet position? Is this necessary. Would not a depression at the outlet be sufficient? My architechts drawings show neither. I am going with posi-joist, firings, 18mm OSB, VCL, 220mm insulation (120mm on green roof), mechanical fixings, EDPM. Firestone mention topping the insulation with 12.7mm ISOGARD HD which is fibreglass covered PIR - is this necessary, why not 11mm OSB? -
Thanks @Nickfromwales I'll ask them. I'm struggling a bit to physically incorporate separate zone valves for new and old rads due to existing pipe runs Do you think they are necessary? Would rad TMV's be ok instead? If you have time a schematic would help me confirm what I need. Thanks.
- 27 replies
@Nickfromwales, just thinking about ordering (cylinders2go?). Presume that the buffer doesn't need a separate expansion tank or prv as it uses the one on the system boiler? Still wondering if a TS would be a simpler and cheaper install?
- 27 replies
Thanks @Nickfromwales, invaluable advice as always. @CC45 thanks for the post, yes it was join the dots but point taken. @Nickfromwalesany view on boiler make, leaning to what I know so Grant, and if you have better schematic then I'd welcome it.
- 27 replies
High praise indeed @Nickfromwales. now would you use the same tappings for rads and ufh as below or seperate? What other components are missing?
- 27 replies
- 27 replies
As I'm now moving the boiler outdoor then was looking at an outdoor version of what I have, Grant 15/26 Vortex Pro outdoor system boiler unless you recommend otherwise. Those were heat figures,, actually I got more like 2.9kw (primarily due to the glass link with the old house so could be a bit more) + 12kw and I guess add 3kw for DHW? Controls wise, room stat per zone and one for ufh I guess or would you go whole hog with Evohome and rad valuable etc, probably ££££!
- 27 replies
@Nickfromwales thanks. I've only got PowerPoint so difficult to sketch in it. Yes I see what you're seeing but I think it's just my drawing. The return from the buffer should go to the other side of the boiler pump as should the return from the uvc. A sketch would be great if you have time, advice on controls even better. The existing is drafty in comparison, will work on it in the future but esimated that it takes 12kw vs 2.5 kw for the new!
- 27 replies
- 27 replies
@Nickfromwales, are you saying that the rads would be better off the bufffer then? Is that why you suggetsed 120L? Otherwise Tevor suggested a 90L for just UFH (70 m2). Trevor also pointed me to merchants such as Cylinders by Choice rather than direct sales. @PeterW does you buffer supply just UFH?
- 27 replies
@Nickfromwales, rads direct off system boiler? Would you put the UFH manifold at the buffer tank, the circuit is 5m away.
- 27 replies
