Everything posted by DevilDamo
It will not be foundation level as those depths can vary. Can you upload an extract of the drawing?
Planning Officer asked if we want to withdraw
DevilDamo replied to Jo J's topic in Planning Permission
How was the breach dealt with? -
Engineer’s local to the project can be an advantage. Otherwise… https://www.fiverr.com/
Cost for building regs: is £950 a reasonable price for this?
DevilDamo replied to Co1's topic in Building Regulations
Ok and which is why BR’s are required as you’re pushing out the thermal envelope. -
Which isn’t dis-similar to the CIL self-build requirements.
Assume you’ll be removing or replacing the original front door then because if so, it’ll be a single storey front extension. As you’ll be carrying out the works in stages, they have calculated the fees as separate projects. If you were to carry them out at the same time, then they would only need to carry out one set of inspections. -
Does the porch actually require BR’s? If so, will you be carrying out the porch and extension at the same time? -
Something to note… Planning is not normally required to change or insert or new windows. So the developer swapping those positions may have well aided their application. Although you think it has hindered your application, the window even in its previous position would have put a limit on your proposals anyway. -
To the rear of no. 46 is a window and French doors. As those openings serve one room, then the LPA can decide which opening to take. The new dwelling (no. 46a) breached the 45 degree line line from the French doors but was acceptable from the window, which is why it was approved. Your proposal breaches the 45 degree lines from the French doors and window, which is why the LPA are stating is the issue. So your options are to withdraw or allow the application to be determined. Bear in mind that the former will not provide you with a formal decision to Appeal, nor will you have the Officers’ Report to cross reference to. -
I have found the application for no. 46 myself. The new dwelling did not impact a 45 degree line, hence why it was approved. -
But he still owns them so the LPA may be a little more relaxed with that breach. But is there a plan that shows how the new build house breached a 45 degree line? Even still, applications are determined on their own merits. -
But the new build house is under the same ownership as your neighbour? -
LDC applications to confirm works are PD do not take into account the 45 degree line. Prior Approval (Larger Home Extension) applications will only take into the 45 degree line if that impacted neighbour objects. But as mentioned, the PA application wouldn’t work as it wouldn’t comply with Class A of the GPDO anyway. As per your LPA’s own guidance, the window from the outbuilding should not be taken into account as it does not serve a habitable room. -
You stated the window replaced some doors so the breach would have always been there. The fact it is now a window is kind of irrelevant. I would argue the breach to the north but I don’t think you can do much in relation to the south. -
Windows to non-habitable rooms should not be taken into consideration for Planning. Whether they may be taken into consideration in relation to Right to Light is something different. I’m not sure why and even more concerned the LPA have suggested a Larger Homes application as that proposal would not comply with the Class A requirements. You may be better going down the PD route to infill that area between the rear and side walls. You may end up having to build it and then apply for the additional rear element. Some LPA’s are more pro-active than others. -
Can you upload a Block or Site Plan? -
LPA accepting public objections outside consultation period
DevilDamo replied to flanagaj's topic in Planning Permission
Local planning authorities may, at their discretion, take into account comments that are made after the closing date (but have no obligation to do so). -
A phased approach to BC drawings / approval?
DevilDamo replied to Alan Ambrose's topic in Building Regulations
LABC’s have up to 2 months to make a decision on an application. If you only submit some of the information, did they then issue a conditional approval so the rest can be submitted later, i.e. after 2 months? -
Box guttering with warm roof, is it possible?
DevilDamo replied to Tuppers's topic in New House & Self Build Design
@Tuppers On the assumption you are working to a maximum roof/ridge height, then adopting a cold roof isn’t going to make a huge difference to the internal height. Overall, a the build up of a warm roof is quite a lot thicker than a cold roof hence having that space to play with. -
@Russell griffiths So were the LABC happy to issue a Conditional Approval which meant everything else could follow later? -
Certificate of lawfulness for Porch replacement
DevilDamo replied to tokyotecubate's topic in Planning Permission
You don’t submit for PD. You submit a CoL to to confirm the works are PD. Retaining the door behind doesn’t have anything to do with Planning. That’s Building Regulations. If you submit a CoL now, it’ll be cheaper than doing it during or later. If you don’t, just make sure you document and/or photograph the works with date stamps so they can be used and referred to in the future. My opinion would be submit the CoL but don’t let that hold you up from starting. Then before you know it, the decision letter will come through and all is well.- 1 reply
Why is a warm pitched roof being proposed? A cold (vented) roof would be more common but you can still achieve a similar detail with a warm roof. -
“Today, January 14th, the Government released draft legislation to propose an increase in planning fees. In many cases this will rise by 100% or more. Although one exception sees an increase of 583% – albeit for major developments.” ”It is advisable to ensure that applications and fees are submitted before 1st April 2025 to avoid these fees.” https://www.planninggeek.co.uk/2025/planning-fees-to-rise-by-100-or-more/?fbclid=IwZXh0bgNhZW0CMTEAAR26SclFk_S3AicapEEurhIj9S-Qz30Dbua-3_X5QgdNU2iU18rc1O-x03k_aem_H4kiMPUHzBe3ZX6APKng5g 🙄
Yes, it is possible subject to notifying the neighbour via Certificate B on the Planning application and then again via a Party Wall Notice/Agreement.
