Everything posted by DevilDamo
LPAs playing around with 'validation' timescales?
DevilDamo replied to Alan Ambrose's topic in Planning Permission
Well that is (or was) down to your Architect to query as that is not how applications are validated. -
Foundation Under Garage Door?
DevilDamo replied to Tomsbuild29's topic in Garage & Cellar Conversions
Correct. -
Whether they are “dumb” is a matter of judgement. And btw, use the “quote” function. -
I’m not sure what you’re trying to prove? That reads you submitted the application on 30th January but it was invalid. It then took about 3 weeks for the correct or additional information to be submitted and the LPA then deemed the application as valid. -
That wasn’t what you originally asked. The answer to your next question is dependant on their workload. If the application is deemed to be valid at the time of submission, then it will be backdated. -
The application leaves the PP system and is transferred to the LPA once the fee has been paid/dealt with. -
Approval only comes via a Full Plans application, which in my opinion is a little overkill for a garage conversion. And the thickness of insulation is dependant on the P/A figure. -
No they will not or should not, especially since the implementation of the BSA. -
Read PD extension - measuring 'height'
Is that adjacent to the structure… -
If you deviate from the approved drawings, you would require re-approval. What do the elevation drawings state/look like?
In a nutshell, yes. Or they may be able to issue a “decline to determine” outcome. Either way, it would mean you having to go back through the Planning process again and pay the relevant fees.
@Alan Ambrose Still not getting used to the quote function so others would receive a notification when you quote them…? @mjc55 It varies between LPA’s but the majority need a push to keep applications on track.
@Canski Excavations to form retaining walls are deemed as an engineering operation, which require Planning. Assume you ended up getting or needing Planning for that reason? @Alan Ambrose The guidance is very clear when measuring on sloping sites. No need to over complicate it. -
What building regs apply to a wooden garage,?
DevilDamo replied to joe90's topic in Garages & Workshops
The 1m and 30sq.m relates to BR’s, not Planning. -
No reason to amend them. If you’re wanting to change any elements, then you may need their approval to copy or reproduce them. But do check the previous T&C’s.
- 1 reply
Demolition exterior spiral staircase, permission needed?
DevilDamo replied to Zab's topic in Planning Permission
A Lawful Development Certificate from your LPA would confirm the Planning situation. You would have to check if your LABC offer something similar for Building Control.- 6 replies
- demolition
- building control
@Bruce The floor area relates to Building Regulations, not Planning. If it’s within 2m of a boundary and under 2.5m high, then it would usually be exempt from Planning. -
No applications required.- 6 replies
- demolition
- building control
