Everything posted by Omnibuswoman
Kitchen installed and bathroom almost done.
Omnibuswoman commented on Susie's blog entry in The Old Cow Shed
Well done. Amazing work. That wet room is fantastic! I have one yet to do on the ground floor, and have drawn inspo from your beautiful tiling -
I have flooring going down next week, and am considering whether to fit the bottom frame for any fitted cupboards now for the carpets to be fitted up to, even though it could be 6-12 months before I get to building the actual cupboards? Or have the carpets fitted wall to wall now, and butcher it later when I’m ready to build the cupboards (provided I don’t change my mind before then!!). Any and all advice /opinions welcome!
Great work!!
I will look into suitable underlay for solid flooring, and some thick fluffy socks for HWMBO to wear when we have visitors!!
The room is a guest bedroom and above it is an open plan kitchen diner with solid floor surface (or it will be once it is finished) so the main thing is stopping HWMBO’s clod-hopping from waking our lovely visitors. I will use acoustic sealant around the perimeter.
Thanks @SteamyTea. I hadn’t been aware that the bars differed for double a board load, so I don’t know whether the ones I got are suitable. I will now check!!
Sadly not… the boards went up so I will need to take them down and add in the woodscrews 🙄. At least I haven’t paid him yet… that isn’t going to happen now.
This just made me think - I think he used drywall screws to fix battens to the ceiling upstairs. Does that need to be redone too?
Given how few boards he got up today I will just take them back off tomorrow, double up the screws, and refit the boards. Then will start looking for a replacement boarder…
Thanks. The ceiling will be double boarded so it is important he knows where the joists are. Or if I bin him I need to know where they are!
Thanks Nick. So in terms of noise transfer, the wall contact isn’t an issue?
In an effort to move forward more swiftly I have hired in a local chap (retired ceiling fitter) to help with plasterboarding the ceilings. So far I’ve been underwhelmed with his fairly messy work (favourite phrase “that’s what plasterers are for”). Today he fitted resilient bars and they are touching the wall in places (see photos). Is this still ok (as he tried to assure me it was) or should I move them?
Ours requires the batteries to be connected and holding charge before it will work. When our battery malfunctioned and completely discharged, the inverter would not come on.
Hmmm we have had repeated water ingress at the edges of a few of our window frames several hours into a storm, which is likely to have wetted the cellulose within the wall cassette (our wall make up inside to out is propassiv OSB, warm cell, wood fibre board, membrane, cross batten, render board, render). I'm now wondering whether I ought to be exposing and checking these areas before we cover them with plasterboard....?
chatGPT and the like for landscape inspiration
Omnibuswoman replied to Post and beam's topic in Boffin's Corner
I was pondering this very question this evening as I’m planning to get outside for a few days in light of the good forecast from tomorrow… have you given it a go? Any feedback? -
I set up our new starlink at the weekend, just resting on a workbench in the garden at the moment. I’m now mulling on how to fix it permanently. Can I ask what brackets you bought for attaching it to your house?
I have noticed that the bottom of the metal shoes holding the ends of the I joists are slightly below the level of the joists themselves. I'm shortly going to be plasterboarding the ceiling, and wondering how to overcome the difference in depth. Should I cross batten the whole ceiling to create a level surface, or shim the face of each joist with something of the same depth (around 4-5mm), or just not worry about it? I've noticed that if I screw PB into a surface with a raised point it makes stress noises - what I don't know is how much this matters....?
Low points: and how to get out of them
Omnibuswoman replied to ToughButterCup's topic in General Self Build & DIY Discussion
Thanks all for the supportive replies. This forum is one of the best sources of support a self-builder could have. I want to give special thanks to @BotusBuild and @Fallingditch for their generosity with both practical and moral support, and to @Gus Potter, @Nickfromwales, @ProDave, @SteamyTea, @ToughButterCup and others who have responded to threads and direct messages with advice and wisdom that I could not have managed without. Knowing that you guys are here, and willing to show such kindness and generosity with your time and knowledge, is invaluable. -
I was drawn to this thread as I was badly struggling for motivation in the couple of months before Christmas, especially trying to undertake tasks single handedly that really required someone with 8 arms, and a lot more height and strength than I have. I eventually got to the point where I was barely achieving anything, and getting more and more self-critical and fed up. Constantly tired, frustrated, and aching. I decided to speak to my GP and started taking anti-depressant medication, which has made a tremendous difference already. In addition, I decided to take up the offers of help that people have given me, and aimed to structure activities around that help in a way that makes it feel the most effective, eg. getting some large boards up on the wall with a few screws so that when I'm back to working alone I can do the simple task of filling in the remaining screws. It isn't even slightly surprising that the pressures of undertaking a self building project can have a negative impact on mental wellbeing. Even the most optimistic of us can get worn down by the feeling of it being relentless and interminable. Asking for help can be transformative.- 107 replies
- 11
I don't have green fingers, what to do?
Omnibuswoman replied to Post and beam's topic in Landscaping, Decking & Patios
You might consider getting a digger and driver to scrape the very top layer off, or scrape it into a bund at the edge of the garden. This should even out the ground and pull up the scrub. We did this, but then left it untended for a couple of years and the brambles did unfortunately return. It takes a number of years of continuous work to get brambles out permanently. -
Does aerobarrier negate need for airtightness detailing?
Omnibuswoman replied to SBMS's topic in Ventilation
That’s a great result! -
I have been out to see what the finish looks like… when the porch was built (recently) the guy squirted some foam under the window and added a strip of trim (possibly an offcut of a composite decking board from the look of it). So, the question is should I get the foam gun narrow tip and squirt in some expanding foam from the inside to stop air ingress? Thanks, M
Thanks @BotusBuild, @Iceverge, @Redbeard and @Nickfromwales for your replies. Botus is right, the MVHR is not yet commissioned, and the humidity in the house sits around 65%. We use the German method of 'shock ventilation' regularly, but the humidity remains relatively high as the area we are in has a rather damp climate. The house has been heated for the last year and sits around 20-21C almost all of the time. I've been closely monitoring this recently via a Shelly H&T, and found that it fluctuates very little with the lowest reading being 19C. In answer to the questions: @Nickfromwales, I'm not sure entirely what you mean by thermally broken... the window is a non-opening one. I also suspect that there is foam missing from underneath which is why I was mulling on the option of injecting expanding foam beneath the frame, however I was worried about potentially trapping moisture and making the problem worse... I will go outside tomorrow to have a look at it from the outside. There should be a strip of compraband filling any gap beneath the frame, so I will look for that. The window also has a lead skirt outside of it as the porch roof sits just below the bottom of the window. It may be that this is acting as a cold bridge. @Redbeard the OSB is only on the inside of the window frame. It doesn't cross the thickness of the wall to the outside. The OSB feels damp, but I think that is from the condensation on the green fabric. I will investigate further tomorrow and report back. @BotusBuild, I will give you a shout if I need a second pair of eyes on the issue, thank you
