Pocster
    29
Everything posted by Pocster
  1. Dynamic creative organisation??
  2. From what I’ve heard he is ..... Can’t say which member of admin said that .....
  3. @Gav_P just shat himself for sure ?
  4. Admin - I’m being picked on can you grow a pair and intervene? no ? Oh there’s a surprise
  5. Yeah respect @Big Jimbo ; you (expletive deleted) want to take a swipe big Jimbo who is 5ft nothing and a skinny puny shit will not sort you out ! .
  6. With the greatest of respect maybe if you fought planning for 5 years to get planning to build an underground non standard house with zero knowledge in this field you would understand. What have you built / done ?
  7. Oh yes . Record covertly all planning / council meetings . A few gems may well appear .
  8. @Jess27 I looked briefly at your proposal . If I can get planning in the most arrogant self righteous toss pot area with the wealthiest neighbours who have the council planners as “ friends “ then don’t you dare quit . Adapt . Turn opinion into fact . Planning is only half the story the other half is politics - I can guess what you think of that . So mitigate or reduce an alleged issue . Compromise where you need to . Play your worst hand so you can come back with your best hand . Though I’ve offered you no technical usable advice - you got this ?
  9. Hence have multiple things on the go !
  10. Don’t like the clasp as it’s pulled out and is just weak . Will order new hook as you suggest ! Failure is not an option ! ??
  11. I didn’t mess with the clasp - bet you did though !
  12. Nothing too see here ! Walk on by ! Tray up ( very carefully watching the hook ) timber propped underneath . There it will stay until a nicer ? hook solution is found . No drama . Oh look ! A forest ? ! See it !?
  13. Another completely random example might be say you were lifting a heavy shower tray with a winch and the straps came off the hook . You’d probably be inclined to “ go and do something else “ at that point in time .... ???
  14. When it’s above me I prop a length of timber across it . Winch is taking no weight - it’s relatively safe perched on timber . As I said I like to test and try a few times to get everything in the right place . No good getting it wrong and trying to lift it out on my own from a corner . Problem was the crappy clasp on the hook pulled out . Need a lockable clasp on a hook that can go on a cabled winch . I’m never under the tray when it’s moving up or down - I’m not that stupid ! ? This is a safe method !!
  15. Not happy now ! Tray seems ok . But how do I make sure these don’t slide off the hook !?
  16. Oops ! F ! clip slipped off hook . Tray fell maybe 30cm !!! ?????
  17. Tell you what guys . This is the way to do it . Lower to test placement , raise and secure . Then amend Easy ! ?
  18. Yeah I was thinking a bit of silicone . Is rather crap especially for an expensive tray . The instructions say the drain must be at the other end from the shower . So you effectively have to walk on it ?
  19. Had a quick look at this . The drain has no grate - is that correct ? Also the cover seems a bit crap - it can slide around and just sits on some rubber legs ( one is broke ) . Is that it ? . Going to clunk and move when you step on it . Am I missing something ???
  20. My new best friend!! ?
  21. If I die tomorrow you suckers can finish it for my SWMBO . Good luck with that ! ( finishing it I mean not SWMBO )
  22. Equally I may eventually realise I haven’t got the right part or I haven’t got a clue what I’m doing . So I stop . Find something else that I haven’t got the right part for and I’m clueless about .An infinite loop of micro progression!!! . A perfect formula !
  23. You made me laugh Because (for example) I might grout a wall in the ensuite then as I don't want to get dust on it or mess it up start on something else. TBH it was always my plan to skirt between bathroom and ensuite. Do a bit here , do a bit there. Demoralising? After 7 years I LOVE IT! ( for the most part )
  24. I now flirt between the ensuite and the bathroom . As tray is relatively safe ,work begins on its drain and support
  25. It’s not sold and you know it !
