Pocster
    29
Everything posted by Pocster
  1. I’ll give you 11k if it locks this thread ! A suggestion from my Psychiatrist
  2. This thread started around the same time as the global pandemic. Is there any correlation?
  3. Why ! What did you see that I had done wrong ?? ?
  4. I’ve just installed 5 of these with no issues . As only some seem to be causing an issue I’d change them to a different flow and return . If they still play up swap the wiring in the control box . Then it’s either faulty actuator ( unlikely to be 3 though ) , faulty wiring box . After that you could just ‘waste’ 50 quid on a different wiring box - just too see what happens ...
  5. Only ensuite shower . Here you go - what’s the question ?
  6. I’ll go back to sleep then
  7. Yes. Still waiting for ransom to be paid! NO BITCOINS!
  8. For the record. Thursday is virtually Friday so wine is allowed.
  9. It is difficult/ can't be bothered to work out what's poe and what isn't. So; I ordered 2 of the fanless poe switches ( giving me 32 poe ports ) and a cheap 16 port non managed poe switch. I'll swap over to that. Everything is labelled so *in theory* I can see what needs to be poe and what doesn't. I use poe for most things though. All sensors for example, ip cameras . I'll report back on these fanless poe switches once I have them. Next time I'm down there I'll measure the db off the netgear switch!
  10. Sorry don’t . Only a (expletive deleted) wit would build one of them
  11. Just thinking out loud here .... Those window frames . They do have glass in them ??
  12. I used vips in my ground level flat roof due to the minimal depth I had . The problem is they come in fixed sizes and obviously you can’t cut them ?
  13. Looks like sewage
  14. A man after my own heart. Not a penny wasted
  15. If you look back in the thread I actually already told you them
  16. 152.441.46.1 is the boy ! ?
  17. Attempting wc in main bathroom . It would seem supplied waste pipe isn’t long enough - assume geberit do a longer one
  18. Sad (expletive deleted)er ! Get a life ! Go and sort Zoots heating , or door , or damp , or ......
  19. As reported by Tesla app And of course is a recognised unit https://en.m.wikipedia.org/wiki/Kilowatt-hour
  20. Got my HA code running . Heating for entire above ground if temp drops below 17c then off at 18c I deliberately did a tight range . Heating came on just after midnight , turned off just after 9am . So effectively I ‘leaked’ 1 degree in 9 hours ( outside temp now around 7c ) Electric consumption for yesterday was around 12kwh . Although not a particularly scientific test - that seems pretty good too me
  21. Dgtvnjjnb gbbbn !
  22. Cross post . I’ll count up tomorrow
  23. I think I might split it A switch for non poe and a switch for poe . Then I can daisy chain off either to extend
