Everything posted by Pocster
Current delivery on high ram bins is 5 months + The ram shortage is effecting Apple now let alone before new hardware appears .
Global ram demand for hi bins ; nvidia etc . Not easy for Apple that’s sure . 96gb I’ll be ok with . Ram shortage set to continue until 2027 maybe 2028 until new production comes online . Can you all stop using chat and Claude please !
Gave up . M5 ultra who knows when ! Probably wwdc . But try ordering a 256gb m3 ultra now … delivery august! Ram delays crippling everything . So decided to buy a stop gap after a few failed attempts on eBay I.e paid ; then eBay refund as scam / issue . Found stock at believe it or not curry’s - but only the m3 ultra 96gb - so that arrives tomorrow.
Oops yes ! . wtf was I on . Anyway if anyone wants to build a machine to impregnate with an AI hybrid life form I’m more than up for that .
lol yeah I’ve watch his videos . But ! I’m not just using local llm to write code ; the house will be controlled via realtime local llm ! . Ever watched the film with Julie Andrews ? Not the sound of (expletive deleted)ing music !! Demon Seed …
I know ! I know ! But I’m planning a 5 yr project . The thing is I could go less say 128gb or 256gb but …. If that becomes a limitation I’m going to be real pissed . So I decided get something that in theory can’t be limited except by my ability rather than hardware .
Global ram shortages biting badly due to AI server rush . Decided go big or go home ( a man behind back of a pub said that to me once ) . 512gb got to be! ; if available . Roll on April 1st ( Apple 50th ) or wwdc ( early June )
ESP32 S3 m5Stack Cores3 swmbo friendly watering system!
Pocster replied to Pocster's topic in Boffin's Corner
Deployed ! code not an issue with ChatGPT but the supplied analog to digital converter that came with the probe is shite . Completely non stable readings even when not in water ! Quick chat with my best mate and we ordered a different one . With current code worked instantly. The percentage water remaining seems incorrect ( though the calcs were based off the tank height ) . Rather than bring in and reflash ( didn’t add OTT updates ) - might just frig the number by a multiplier to scale it better in home assistant .Doesn’t need to be especially accurate but reasonable . -
Finally deployed and wired up . It would seem some speaker connectors are wired wrong way round ( though I checked a zillion times ! ) . But no worries . Not told SWMBO - so that’ll be the ultimate test !
Raft foundation - close to existing structures
Pocster replied to WisteriaMews's topic in Foundations
Even I got an SE at the start . Foundation stuff is critical. Even if I posted on here still want an SE to spec and check . So op post details for sure . But get an SE aswell . This isn’t going to be a few hundred quid if you (expletive deleted) up . Once foundations are done you can just wing it like me and not give a (expletive deleted) . -
The fitting at the wall end is fixed to the spring base - so it is just 1 hole .
This spring gate closer was a tough (expletive deleted) to install . After under a year it’s pulling out the quoin . Assume quoin is quite soft . What fixing do I need so this mofo doesn’t pull out ?
Yeah I meant about the bar keepers friend 😉
Tested uma8 . Really good . Sensitive enough and direction of speech can be retrieved .
Already ahead of you . Got a usb powered fan to install
Don’t know ; “ Andrews a nonce “ ???
(expletive deleted)ing depth sensor ! It’s shite ! Or at least the beam is so wide it’s useless in a water barrel -
Ain’t got any . Using abs -
My cad skills limited
